what would happen if this OME part was forgotten
There are two bushings for the OME shock / coil kit in front. One goes on the stem under the top plate, and the other goes above. Would there be any negative effect if, say, the one under the top plate was not installed?
You would probably get a pretty loud squeeking eventually. Also if the top nut was tightened all the way down and there was no lower cushioning it might be possible to do damage to the shock rod. You would probably hear a clunk when the shock compressed too as there isn't enough threads to tighten it down all the way without the bushing.
As much of a pain as it is to compress the coil again I would recommend putting it in......that is if it were left out.
You definetly need something in there.
If you dont, then you';ll get a nice loud knocking noise everytime you go over a bump. I had mine installed, but, the top plate wasn't compressed far enough to get a tight fit inbetween the top nut and the two bushings.
There was a black one (bushing of some sort) in there which popped out the other day, and I was hoping it wouldn't be a big deal to leave it out. It's easy though, I'll be working on it this weekend and pop something back in.
(for the record I would like to state that this had nothing to do with the installation or the kit I received - all the parts we reused on mine were pretty old and beat up anyway, so it's no surprise that with some change in there one of the old black bushings finally revealed previous damage done to it)
If it is indeed out, you should have clunking. For the life of me I can't imagine how it could 'pop' out, because your bushings looked to be fine to me. I'll help if you want- like I said I can pull the coilover & compress it down in a jiffy here at the shop if you want to take a quick look & make sure. If we can do it after work today, and it does indeed need replacing I should be able have one here by Saturday and can break it down & swap it for you since I'll be here anyway.. (and if indeed it did fail, I'd rather get two for you and do both sides just so we'll be sure you'll be OK)
It's okay, I'm planning on taking a look at things this weekend and I'm pretty sure I'll be able to tell where the part came from without having to compress the coil - just need a better angle to see it.
All I know is that I was washing the truck and a big black bushing (which looks much like the ones on the shock stem) came out and washed down the driveway. There is some clunking when I go over bumps, but I am uncertain as to whether that is the OME kit being stiff and just taking some time to soften up, or if it is the thing I found washed down the driveway.
Like I said, I'll be at work Saturday- if you have trouble ID'ing it you can swing by.
Thanks, I plan on looking at it tomorrow.
Believe me when I say that I know where the strut bushing goes.
(p.s. -- i heard a rumor it's your birthday!! i hope you have a wonderful day!!!! ... with lots of Miller High Life!!)
Road Bull
Oct 10, 2015 04:55 PM
jon.r
Jul 11, 2015 03:34 PM
88runnergomas
Jul 9, 2015 01:12 PM
