Metallic Fluttering Noise
Old Jul 3, 2005 | 12:39 PM
quik05's Avatar
After a trip all over central Kansas my old 4 banger has started to make what I can only describe as a metallic fluttering sound. It only happens in a medium/low rpm band. If I go higher in the rev band it goes away, If I lug it a little in a high gear it goes away. My first inclination was something in the valve train, but upon futher reflection the timing chain slapping around would probably make the same sort of sound, the truck only has 84,000 miles on it.
Please Help!
Old Jul 7, 2005 | 04:38 PM
quik05's Avatar
Come on guys a week, and no one has ANYTHING to say!
Old Jul 7, 2005 | 06:42 PM
PWDR PG's Avatar
sounds like a timing chain. mine makes the same noise at around 2-2400 RPM. Although, mine has over 150,000 on it. That sounds like low mileage for a timeing chain but that stil could be your problem.
Old Jul 7, 2005 | 08:08 PM
rugerm44's Avatar
Dose it make the same noise for a few seconds at start up.If so chain tensioner.Once oil press builds up it gose away.
Old Jul 8, 2005 | 10:01 AM
ricky's Avatar
Yup, it's the tensioner most likely. I had this same problem in my old truck with the 22R. It makes the noise at startup then goes away after about 30 seconds once the oil pressure builds up. The tensioner is basically a hard rubber boot and the timing chain will dig into it after thousands of miles. Thus, it can't properly tension the chain, so it makes noise. Time for a new chain and tensioner.
Old Jul 8, 2005 | 02:26 PM
quik05's Avatar
Well, it does it all the time, and it only goes away if I rev the engine, no matter how long it has been running.
gibbonsballer10
Oct 26, 2023 07:13 AM
langry345
Sep 14, 2015 03:36 PM
Streetrod19772000
Sep 10, 2015 06:22 PM
Mrfobbyaccent
Sep 10, 2015 12:13 PM
Kreedy1
Sep 8, 2015 06:33 PM
