3.0 part, can you identify this hose?
Old Jun 20, 2005 | 02:29 PM
weezy's Avatar
I have a rigged hose of some sort that is whistling and coming apart. Right now it is made out of some copper tubing and hose insulators, but I know that isn't what is supposed to be there. Like I said there is air passing through it so it's vacuum related? I dunno ..... here's a pic of what I am talking about. Any help would be great.
Old Jun 20, 2005 | 02:37 PM
94x4's Avatar
Guest
No "picture" weezy. Try again.
Old Jun 20, 2005 | 02:42 PM
weezy's Avatar
hmmm ... I see one, can anyone else?
Old Jun 20, 2005 | 02:45 PM
NRM's Avatar
NRM
i see it, not exactly sure what it is though
Old Jun 20, 2005 | 03:37 PM
weezy's Avatar
Does anyone have a photo of the passenger side of their motor I could take a look at?
Old Jun 20, 2005 | 03:58 PM
callmej75's Avatar
looks like the pcv valve hose
Old Jun 20, 2005 | 04:00 PM
Steveh29's Avatar
I'll go out and look at mine after work and trace where it's going if nobody can answer this. I also have the shop manual at home and can scan the pages with this vacuum routing stuff if you need it. As I recall it's a large diameter vacuum line that runs to the PCV valve but I've not had my intake off in about 2 years. If it's a line that comes out and does an immediate U-turn and goes under the manifold, that's what it most likely is because the PCV valve is directly under the manifold on that side.
Old Jun 20, 2005 | 05:16 PM
justanother4x4's Avatar
definatly the pcv valve line, just had my intake off 2 weeks ago
Old Jun 20, 2005 | 05:20 PM
dstrick32's Avatar
Could very well be the PVC can't really tell looking at the pic but also looks like somebody might of done away with the vacuum switch on the power steering pump and made a by pass loop!!
Old Jun 20, 2005 | 05:28 PM
Ganoid's Avatar
Its tuff to tell but it looks to me like some one pulled the hose off the PCV valve and simply pushed it over the stud holding the EGR on. I will go get a pic.
Old Jun 20, 2005 | 05:34 PM
callmej75's Avatar
In that pic there is 3 vacuum lines that aren't hooked up...didn't know if they were known or not.
Old Jun 20, 2005 | 05:39 PM
DudeBud's Avatar
yep these right here
Old Jun 20, 2005 | 06:50 PM
weezy's Avatar
Yeah, I took those off to get a better pic and to get to the 'homemade hose', but thanks for pointing that out cause I forgot to put them back on!
Old Jun 20, 2005 | 06:54 PM
weezy's Avatar
Ganoid .... you showed me what I needed to see, THANK YOU. I still don't understand why one would rig it in such a way (shrug). Thanks to all who gave input, much appreciated!
Charecter1
Nov 6, 2023 10:08 AM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
Roger Borba II
Jul 9, 2015 05:05 PM
Avenged
Jul 9, 2015 07:55 AM
