Sealing a leaky oil drain plug
Wow! I just changed the oil on my Celica and this drain plug is LEaking big time. There is a huge puddle under my car. I tightened it down too. The threads shouldn't be stripped. I didn't go that hard. WHat is the best way to seal these things? teflon tape? Blue loc-tite?
Suggestions?
Suggestions?
might just try a new gasket/washer from the dealer...cost a buck or two.
they are deformable metal, so, theoretically, you should use a new one everytime (since the metal is supposed to deform to match the irregularities of the two surfaces), but, in reality, usually you can get away with just reusing them many times...but, eventually they do wear out.
I've been a lot happier with copper washers. They're available at most auto parts stores and usually stocked with filters or oil. I believe the brand that Pep Boys carries is 'Oil Tite'. Anyway, I like the copper ones because they don't crush as easily and leak. Just my experience.
cool I'll go get a new washer with my new 5 quarts of oil...damn!!!
hopefully autozone or kragen has one. The one on there now looks like black plastic
You can even make one if you have to. I have made them out of things like a plastic quart oil bottle. Just cut it out to fit over the drain plug. They will last at least an oil change or two (maybe more) before you have to make another one.
Sounds like drain plug gasket to me. My WRX had a crush gasket that I replaced on every oil change. Something like that maybe?
Yeah, those fibrous "crush" washers seem to work pretty good from my experiences with various cars.
From: Far western Kentucky (transplanted from central PA)
And, of course, be sure both surfaces of the washer, the mating surface of the oil pan and the threads on the plug are clean. It doesn't take much grime or grit to prevent a good seal.
