Rust, an enemy of the 4 runner
Old 05-16-2005, 02:19 PM
theryanator's Avatar
I was under my runner today tinkering around with the emissions system when I noticed it...the whole underside of my car is pretty much rust. The body itself is in great condition glossy paint, no rust etc...the underside, a different story.
My main concern is the running boards, they are pretty much all rusted underneath, though very little rust has reached the surface at this point. I am curious to find out what the cost to replace the metal part of the running boards would be as I would like to do that prior to them rusting all the way through and possibly onto another part of the body.
Any recommendations on replacements?
Old 05-16-2005, 07:06 PM
Rishi's Avatar
Use two coats of RustBullet !
Old 05-16-2005, 07:13 PM
Ironmike4x4's Avatar
I would maybe grind the rust out then spray rubberized undercoating on them. That's what I did on mine, I did my skid plates, frame, and transmission pan.
Old 05-16-2005, 07:20 PM
green91runner's Avatar
bad thing about a rubberized coating is, if water gets behind it (smack it off a rock) the water can't go anywhere so it rusts worse. honestly, i'd just rip them off, mine had holes right through, and i couldnt be bothered, lets your rockers breath, making less chance for rust, as for the undercarriage, i'd just take it to a rust place, they will clean it all off and spray it down, killing the rust.. do this annually and it should last you a long time.
Jnkml
07-06-2015 01:20 PM
Steezy96yota
07-06-2015 10:00 AM
wilbertd
07-06-2015 07:39 AM
coryc85
07-06-2015 04:07 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: Rust, an enemy of the 4 runner
