O2 Sensor stuff!!!
O2 Sensor stuff!!!
Im looking to run a 24:1 mixture (dont ask)
How would I go about setting my O2 sensor to allow my 1991 Toyota Pickup 22re to run like that?
Thanks,
Bill
Thanks,
Bill
i really doubt that a 22re would even run on a 24:1 air/fuel, thats way too lean, most EFI systems lean out to around 17:1 when cruising, but 24 is too much in my opinion
It wouldnt hurt the motor if the spark was hot enough to completely burn all of the A/F inside the cylinders.
This is a project im working on anywho.
Figuring that you know the issues of trying to run this lean, then the only thing I can think of to make it happen is the Split Second FTC-017E controller:
http://www.urdusa.com/Merchant2/merc...ory_Code=SPLIT
Outside of the normal functions of letting you modify timing and fuel delivery, it'll also fake out the O2 feed and force the ECU into open loop during cruise. That'll stop the ECU from trying to force a Stoich A/FR and let you tune during what would normally be closed loop.
Good Luck!
Good Luck!
Regency
20
01-03-2020 07:43 PM
montanatruck
02-26-2017 07:07 AM
terminator
07-27-2015 07:13 PM
