interchangeability of ifs third 2nd/3rd gen truck?
Old May 14, 2005 | 03:59 PM
rivercat's Avatar
i know nothing about the vaccum accuated front diff found in so many of our trucks, but a friend of mine blew his gears up so... will an ifs third member out of an '86 truck with manuel locking hubs go into a '91 truck with the vaccum accuated diff? just the third member and they're both 4.10's
thanks
Old May 14, 2005 | 06:44 PM
93ToyKid's Avatar
How did he blow a set of 4.10s up? Are you talking just swapping out the gears, or the entire center section? Yes, they are interchangeable, but you won't have the vacuum-actuated diff using the old third member. Which is fine, as long as you swap in a set of manual hubs. Did it on my 89...
Old May 15, 2005 | 09:57 AM
rivercat's Avatar
that's what we we're thinking, i wasn't sure if the vac. actuated stuff was in the pumkin or.... thanks
Old May 15, 2005 | 10:42 AM
kyle_22r's Avatar
'86-95 should all swap if im not mistaken
Old May 16, 2005 | 08:21 AM
mastacox's Avatar
thanks
The vacuum actuated part, that is off to the right... You should be able to chang the stuff out in the carrier. Make sure and check the backlash and pinion depth though, it might be slightly off when you change it...
Old May 21, 2005 | 10:05 AM
rivercat's Avatar
thanks for the help guys, we didn't want to mess with the inturnals at all so we found someone to trade with
AustinTaco
Aug 22, 2022 10:45 AM
Daneums
Jun 29, 2015 06:38 AM
Ott47
Jun 26, 2015 05:21 PM
Bamripzit
Jun 20, 2015 04:53 AM
Chooch
Jun 19, 2015 03:05 PM
