Biggest tires
32's will work if you pound the fender seam up a bit. 33's will work on stock rims as long as the fender seams are pounded and there is a 1" body lift. These are minimums obviously. To compromise you can put on a 265/75r16 tire which is about 31.6" high but the same width as a 31x10.50r15. Obviously that requires a wheel change but I'm just giving you some options.
Not all 32" tires are created equal. Some measure out to be more like 31.25" Width and wheel backspacing has a lot to do with it to.
I run Goodyear MT/Rs 32x11.5 x15 on 15x7 JJ stock wheels with 1.5 inch bodylift and low profile bumpstops. At full steering lock and suspension stuffed I rubbed. I sliced a 3x3x4 triangle off of the plastic lining and there is no more rub.
So I guess the answer on 32s is maybe. Hope that helps.
djpg2000
Nov 11, 2020 04:56 AM
