rough idle
Old Jan 27, 2003 | 05:10 PM
hunster22's Avatar
rough idle
My 3.0 L 4runner 95 (71,000 org miles) recently get rough idle
when shift to o drive position,on park position seeme to be fine. Last year got major tune up by dealer,replace rotor cab ignition,new spark plug wire,gasket head..I just clean fuel injector,replace fuel filter,air filter,clean throtttle intake,no trace for vaccum leak found, no engine light warning. what else should i shoot for,please advise!:pat:
Old Jan 27, 2003 | 05:44 PM
growinseed's Avatar
The idle is rough when the engine is under load and at idle? I' guessing here, but you could check the timing, and check the plugs to see if any are fouled or not gapped correctly. Also when did you last check/adjust valve clearances? Check for operation of EGR and PVC valves
Good luck.
welcome to the board there is alot of good heads here someone will probably have an answer for you.
Nathan
Old Feb 4, 2003 | 07:02 PM
hunster22's Avatar
Thanks for the advise ! problem fixed Fouled spark plug
You are the man****
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
1992pickupSr5
May 9, 2019 08:44 AM
TACOJO
Nov 27, 2015 05:26 PM
markwink
Aug 18, 2015 12:38 PM
