86 22re Fan clutch replacement
Old Apr 24, 2005 | 05:18 PM
pruney81's Avatar
Does anyone have any tips on how to replace a fan clutch in an 86 4runner?
Old Apr 24, 2005 | 11:07 PM
Poopy's Avatar
Yeah, its easy . Unbolt the 4 bolt's on the water pump and the 3 for the fan shroud and lift them out as 1 piece. The 4 bolts are kinda tricky to get to and to make them easier to get to I would bump the starter to get the bolts where they were easiest to reach. To makes it easier I took off the top radiator hose as well.
Old Apr 25, 2005 | 08:10 AM
wimpywade94's Avatar
or just get a 19mm socket on a breaker bar and turn the crank so you can get to each bolt easily with a 10mm open end wrench, the fun part is getting them back on!
wade
mskalmus
May 28, 2017 07:51 AM
MMA_Alex
25
Apr 18, 2017 05:07 AM
coryc85
Sep 9, 2015 06:24 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
zd92655
Jul 5, 2015 04:25 PM
