possible engine swap?
Old Apr 24, 2005 | 04:06 PM
864runnerboy's Avatar
my cousin just got a honda prelude, and is going to upgrade his engine. He is going to get rid of his stock jg30 engine, and so i am wondering if i should consider taking it off his hands and putting it in my 1986 4runner. Question i have is will the jg30 engine fit in my 4runner? will i have to do alot of customization to get it to work? Any info would be greatly appreciated. Thanks
Old Apr 24, 2005 | 04:11 PM
jimbo74's Avatar
welcome to the site.... size wise it might fit as people have put chvy 350s in their toyota... however it will require a lot of custom fabrication work.... most likely its not going to happen becasue it seems you are relatively in experienced and not just that but they are completely differnt manufactures and no one has doen this swap befroe... also isnt the honda front wheel drive? thats just insane.....
so basically if you have a million dollars you could do it... if not, nope its not going to happen
Old Apr 24, 2005 | 04:13 PM
Eddie Monster's Avatar
""i should consider taking it off his hands and putting it in my 1986 4runner. Question i have is will the jg30 engine fit in my 4runner""
my opinion is
#1 it still will be under powered .
#2 lots of fabrication to adapt the honda motor to toyota transmission, motor mounts bell housing , etc etc.....
#3 it will be cheaper to build a HP toyota 22 r then droping a honda motor on a truck
#4 check out Lc engineering or tcr web site im sure they have what you need to modify a 22 r motor .
Old Apr 24, 2005 | 04:15 PM
correction "droping a honda motor on a truck" dropping A honda motor In truck.!!
Old Apr 24, 2005 | 04:34 PM
no the honda engine is rear wheel drive. I kinda figured that i would still be underpowered, but it would definately be better then the stock 22re that comes in it. when talking about the fabrication though i see that mounting to the tranny and everything else would be a pain.
Old Apr 24, 2005 | 05:23 PM
jimbo74's Avatar
ok it still isnt worth it...... you could do a 350 swap cheaper than this because stuff is already made to do it... the r&d has been done.....
Old Apr 24, 2005 | 05:31 PM
Adam F's Avatar
Forget a 350. Go with a 7MGTE. It will bolt right up to your stock tranny and engine mounts.
Old Apr 24, 2005 | 05:33 PM
Adam F's Avatar
No, its front wheel drive.
Old Apr 24, 2005 | 05:43 PM
kyle_22r's Avatar
not to mention honda engines spin backwards compared to other automotive engines.
i wouldn't waste my time with a high revving engine with no torque in a truck though...
Old Apr 24, 2005 | 05:45 PM
Adam F's Avatar
I've never heard of this engine. Do you have any specs?
Old Apr 24, 2005 | 07:13 PM
i will call my cousin and see what the specs are for it.
Old Apr 25, 2005 | 06:00 PM
hafftrak's Avatar
That's what I was thinking. A Prelude would be an F or H series, wouldn't it? JG30 sounds like a Nissan engine code.
Old Apr 25, 2005 | 06:02 PM
DudeBud's Avatar
or a plane motor
Old Apr 25, 2005 | 06:58 PM
Praufet's Avatar
Also, if it is a honda motor, the rotate the opposite direction of most engines. Also I think your cousing meant the vg30de out of the 300zx. Its a decent motor, but not great. Really suped up vg30dett only make around 550, which for a twin turbo motor, isn't great. I'd personally sell the motor and use the money to upgrade the 22re or swap in a 3rz.
Old Apr 26, 2005 | 08:25 AM
hafftrak's Avatar
Talking
Maybe this engine? Might be a bit underpowered.
JG-30
icentropy
Sep 16, 2020 02:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
coryc85
Sep 9, 2015 06:24 AM
