ECU PIN Diagram
ECU PIN Diagram
I am trying to fix the knock sensor problem on my truck (code 53), it looks like the connector is not corrodied. I want to check the voltage from the ECU. Does anyone have an ECU PIN DIAGRAM 1988 V6 4runner.
THANKS!
THANKS!
I have a 22RE pinout on my page, below:
http://www.4crawler.com/4x4/CheapTri...shtml#MoreInfo
Otherwise, try to find a Factory Service Manual and it should be in there (that's where I found the above data).
No idea, but you could at least check the number and pin count of the connectors. If they are different, then all bets are off. But if they are the same, the pinouts may be similar. See if a local library has a V6 FSM to look at.
THANKS!
THANKS!
zytra
Jan 24, 2019 03:16 PM
punks_is_4x4
Feb 26, 2016 04:29 PM
runnermedic
13
Sep 21, 2015 05:20 PM
