ECU PIN Diagram
Old Apr 22, 2005 | 06:00 PM
M threezy's Avatar
ECU PIN Diagram
I am trying to fix the knock sensor problem on my truck (code 53), it looks like the connector is not corrodied. I want to check the voltage from the ECU. Does anyone have an ECU PIN DIAGRAM 1988 V6 4runner.
THANKS!
Old Apr 22, 2005 | 07:36 PM
4Crawler's Avatar
I have a 22RE pinout on my page, below:
http://www.4crawler.com/4x4/CheapTri...shtml#MoreInfo
Otherwise, try to find a Factory Service Manual and it should be in there (that's where I found the above data).
Old Apr 22, 2005 | 08:23 PM
M threezy's Avatar
is it the same diagram?
Old Apr 22, 2005 | 09:14 PM
4Crawler's Avatar
No idea, but you could at least check the number and pin count of the connectors. If they are different, then all bets are off. But if they are the same, the pinouts may be similar. See if a local library has a V6 FSM to look at.
Old Apr 23, 2005 | 01:24 PM
eric-the-red's Avatar
THANKS!
I have the FSM for a 95 4runner that I can eamil to you. May or may not match a an 88, but if you want a copy send me an email address.
Old Jul 17, 2010 | 07:01 PM
Challenga's Avatar
Did anyone ever find a ECU diagram for a 1988 3.0 V6 4runner? I can't find one. It looks like it is year specific. The 22RE and later years of the V6 have a different pin layout.
zytra
Jan 24, 2019 03:16 PM
punks_is_4x4
Feb 26, 2016 04:29 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
bradahman
Oct 1, 2015 09:24 AM
runnermedic
13
Sep 21, 2015 05:20 PM
