86-4runner runs better @ 14 BTDC?
Old Apr 19, 2005 | 11:58 AM
beer eh dee's Avatar
I've been preparing to smog my 86 22rec 4 runner
My Sticker calls for 5 BTDC with terminal t shorted
At that setting I can barely pull out of the drive way. Once I do get going I can reach 55 mph in about 2 and a half minutes. No power up hills even in third at 60 mph. Any low end torque? Forget about it! Gas milage is horrible.
At 12 to 14 BTDC my truck rock and rolls like it should.
Quick off the line. Power up hills. Great gas mileage.
WHAT GIVES? Any Ideas what is "off"?
Old Apr 19, 2005 | 12:02 PM
jimbo74's Avatar
well the cam could have jumped a tooth... i would personally pull the cover and check that the cam and the crank are both correct....
and yes, the 22re is relatively a gutless engine.... it will run better at 14* because its running a lot richer then and rpms are up due to the advance
Old Apr 19, 2005 | 05:25 PM
toddowaddo's Avatar
Same thing happened to me when I adjusted the timing on my '86 22re after timing chain replacement. I couldn't figure out what was wrong, so I took it to my Toyota mechanic/fishing buddy. After he adjusted the timing it ran great, told me he didn't go by the factory settings, just advanced it until it started "pinging" then dialed it back.
the1998sr5
15
Jul 14, 2020 08:35 PM
Doug4320
Mar 24, 2018 10:11 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
coffey50
Jul 28, 2015 10:55 AM
calderp
Jul 27, 2015 09:58 AM
