View Poll Results: What size of off-road lights should I get?
55W
37
24.67%
100W
63
42.00%
130W
50
33.33%
Voters: 150. You may not vote on this poll
Off-road lights: 55W, 100W, or 130W
The time has come to start looking into off-road lights. So I decided it was time for another poll. What size of off-road lights do you think I should go with? 55W 100W or 130W
I ran some Eclipse 100W lights on my Dodge and they worked great and are cheap. I think I may go with them again. Here they are:
http://cgi.ebay.com/ebaymotors/ws/eB...967935983&rd=1
100W seemed like plenty of light to me. I just want to hear what you guys have to say. Are 55W lights bright enough?
Thanks
Thanks
Originally Posted by strap22
Thanks, Jake.
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WD1V
http://www.piaa.com/Lamps/Lamp-pages/80proxt.html
If you want really good cheap lights then go to wal-mart and buy the halogen driving lights (note I said driving and not fog lights). I bought them for 20 bucks and replaced my old tractor beam lights with these and they were much brighter than my high beams. I will use them next to replace my backup lamps and mount 2 more on my surco rack.
couple things to consider-
If you are using the stock alternator, how much amperage to you have to spare? More lights can require an upgraded alternator.
With the radio and amp (if you have one) on, the AC or heater on, and stock headlights, can you spare another 20 to 30 amp continuous current draw? Two 100W lights will pull 15 amps under ideal conditions- I found it was closer to 20 with a meter.
I have two 55W Hella 500's for additional light, but find I use the tractor lights more frequently since most of the stuff I do is at low speeds. I've got two tractor lights that shine on the front axle, tow for the middle of the truck (belly lights) and one for the rear axle, and two more that light up the front tires. In total, the tractor lights draw about 12 amps on a meter, and offer a lot of usable light. With the Hella's on, it adds and additional 10 amps of draw on the system. That's about all I have to spare...
This shows the tractor lights on:
http://www.bajataco.com/spiderranch/L_spider19.jpg
Later
Later
Originally Posted by Jake94
What kind of deal can you get on a set of 60XT driving lights? These would fit my new roof rack better than my KC's
Thanks, Jake.
Thanks, Jake.
Super White Driving Light System (PIAA-6252)
Product: PIAA 60XT Series Super White Driving Light System (PIAA-6252)
$163.39 plus shipping
I'll need your zip code for a complete quote. Reply to: info@trdparts4u.com
Later
Later
Thanks
Ag
EDIT: Does anyone have any first-hand knowledge of running 130W lights on a 3.0?
FWIW, I have the taurus fan and the alternator seems to keep up with it on the low setting. I don't use the high setting much.
Every item that's on draws current, it all adds up.
Two 130W bulbs would draw about 18+ amps (260 watts / 14.2 volts = 18.3 amps) and should be OK to run. What cracks me up is the guys I see with 6 or more mounted - knowing that most of'm don't have the current available to run'm without drawing down the battery.
Wish I could find the video clip of the Rough Rider Ford @ the Baja 1000. They used 3 alternators on the truck and had a light bank on top of the rig for the night run that looked like a outdoor stadium setup. Increadible output - all HID. The video was shot from a chopper, and as they bounced thru the whoops, the light flashed on and off in front of them for what looked to be a mile or better - close, far, close, far...
I know. That's why I don't agree with using an electric fan to get better mileage and power over the long run.
I was just wondering specifically about the AC and heater. The AC is belt driven and I suppose the electromagnetic clutch draws a little current and the heater just uses engine coolant with a heat exchanger to heat up the air. It just seems to me the AC and heater are insignificant.
