Line info needed
Old Apr 9, 2005 | 04:41 PM
ttr125mar's Avatar
Line info needed
Hey while I was trying to pin-point a knock sound I found a large hole (where a hose should be on) it is right under the EFI and I looke it up in my hayns book and is should go to a resonater (spl?) which then connects to a line and then pops in the side of the air intake hose (plastic) then goes into a hole on the air intake. I dont have any of those mentioned above. Will it harm any thing, is it just for emissions. I can get it when I give it gas it is sucking in air, when I let go of the gas you can hear it bog. Also what is the line called?
Thanks,
Mario
Old Apr 9, 2005 | 08:49 PM
frankenrunner's Avatar
Guest
it "sounds" like you are referring to the "pcv hose" line that is used for "emissions" & , yes, it is something that you need & should'nt you know all of this since you looked it up in a "Haynes" book ?!?
Old Apr 10, 2005 | 06:45 AM
ttr125mar's Avatar
The haynes just had a picture of it, it runs along the air intake hose.
Thanks,
Mario
Old Apr 10, 2005 | 07:36 AM
YotaJunky's Avatar
Take a pic and post for clarity.
Old Apr 10, 2005 | 08:06 AM
ttr125mar's Avatar
Here is one I just took.
Thanks,
Mario
JF9243176
Oct 8, 2017 04:21 AM
BigArt70
Jun 30, 2015 09:51 PM
JF9243176
Jun 24, 2015 04:53 AM
HALMAN
Jun 14, 2002 09:02 PM
