Tow Ball Hitch as Recovery Point?
Old Mar 31, 2005 | 03:02 PM
ORB's Avatar
ORB
Is it safe to use one of these:
with a shackle as a recovery point? (It is rated at 6000 lbs while my hitch is rated at 5000 lbs)...
Old Mar 31, 2005 | 03:07 PM
Flamedx4's Avatar
You mean put a shackle in it? Sure. But it might bend the clevis pin if it doesn't support it right, making it hard to remove. So use the biggest shackle that will fit.
Just never loop your recovery strap over the ball and yank. Seriously, ball failure is very rare - but disastrous if it happens.
Old Mar 31, 2005 | 04:39 PM
ORB's Avatar
ORB
Right on...Thanks
Old Apr 1, 2005 | 12:22 PM
Napoleon047's Avatar
another way is to stick the loop of the strap into the receiver hitch and put the pin through the loop.
Old Apr 2, 2005 | 07:38 AM
CynicX's Avatar
There isnt a problem with using that. Its better then hooking onto the frame or something. I believe Warn makes a mount so you can hook a winch to a receiver. If you can winch from it, you should be able to pull from it...well considering thats what its designed to do ....I wouldnt pull more then its rated for of course....remember though, pulling a vehicle that is stuck in mud is gonna be ALOT more weight then the vehicle itself, since the tires will have a suction effect in the mud...
Old Apr 2, 2005 | 07:55 AM
netwt12's Avatar
i welded a front tow hook from a 99 yukon to one and made a big bad tow hook. it works great.
Old Apr 2, 2005 | 08:16 AM
4Crawler's Avatar
I used one of those with a 7/8" shackle for recovery use. I later made a long reach shackle receiver to replace it:
I can't use the std. short reach receiver in my bumper, the pin is set 5" back.
Old Apr 2, 2005 | 04:38 PM
ORB's Avatar
ORB
That's awesome! I wish I had crazy fabrication skills .
4x4-runner
Apr 18, 2017 09:08 PM
Peevedkitten
11
Aug 31, 2015 06:57 PM
dropzone
Aug 11, 2015 05:16 PM
defrag4
Jul 31, 2015 10:50 AM
pyramid
Jul 30, 2015 10:05 AM
