Replacing tie rods,idler arm, cv axle. advice/suggestions?
Old Mar 29, 2005 | 05:31 PM
Praufet's Avatar
As the title reads I am replacing the inner and outer tie rods, passenger side cv axle, idler arm, throttle body (leaky iac), and doing an oil change. Wonered if anyone had any advice, suggestions, or helpful hints for this labor. Thanks.
Old Mar 29, 2005 | 09:19 PM
Mad Chemist's Avatar
Have a good pitman arm puller for disconnecting the outer tie rod ends. I ordered one from Harbor Freight for about 8 bucks, but I know you can rent them from Schucks. I'd replace the bushings on the steering rack while your at it.
Old Mar 29, 2005 | 10:46 PM
dragon564's Avatar
Count the number of threads showing on the tie rod ends...helps to get them back on with out throwing the toe in/out adjustment completly out of whack...
Old Mar 30, 2005 | 04:32 AM
Yoda's Avatar
Since your replacement parts may be slightly different than what is on there now, make sure you measure the length of the tierod (center of the ends)
bigjstang
Jun 2, 2025 03:56 PM
Sep 4, 2015 09:27 AM
razorman8669
Jul 12, 2015 12:13 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
ptb12
Jul 5, 2015 01:49 PM
