new set up im thinking abuot...
Old Mar 5, 2005 | 03:14 PM
4unner4life's Avatar
Tell me what u think abuot this set up....
2 front tundra coils-----152$
2 rear coils (OME 890)-------139$
4 Rancho RSX adjustable shocks---168$
Old Mar 5, 2005 | 03:46 PM
Localmotion's Avatar
I would say go with the OME shocks/struts.
Old Mar 5, 2005 | 03:53 PM
so u say ome coils in the back and ome struts front and back....but with tundra coils up front...? thatll give the front 3inchs of lift and the back 2.5 right?
Old Mar 5, 2005 | 04:01 PM
Im not positive about how much lift i got. But i pretty sure you'll be satisfied I used the the OME 891s in the rear and im content
matt
Old Mar 5, 2005 | 04:47 PM
ok thanks matt
Old Mar 6, 2005 | 02:24 AM
Bighead's Avatar
What makes you think you will get 3" of lift from the Tundra coils?
Old Mar 6, 2005 | 04:40 AM
i thought i read someone sayin that
Old Mar 6, 2005 | 06:23 AM
sschaefer3's Avatar
Tunrda coils give a 4WD vehicle 1.5" of lift. Add a top out spacer for an extra 1/2". For a grand total of 2".
The high point of the OME shocks is the huge piston shafts they have. The Ranchos are OK, but have the very small stock like shafts and the rear shocks are not as long = less travel.
Old Mar 6, 2005 | 11:53 AM
I think i may just put OME coils all the way around...
Old Mar 6, 2005 | 03:40 PM
User 051420's Avatar
Why? The Tundra coils are a proven solution..proven to work BETTER than the OME coils. You can add 2 top spacers to each side of the front, and you'll get 2.5" of lift. The ride will be awesome, and with OME shocks, it'll flex to the physical limits of the suspension. What else can you ask for?
Old Mar 6, 2005 | 03:42 PM
sschaefer3's Avatar
I would not.
Old Mar 6, 2005 | 03:48 PM
FilthyRich's Avatar
This is a no brainer. Read the million page thread, this setup works. So do other routes, but this seems to be THE ideal DD setup.
Old Mar 6, 2005 | 04:25 PM
wouldnt two spacers kinda of preload the coil?
Old Mar 6, 2005 | 04:26 PM
No. Read the threads on the setup. The spacers go outside of the assembly, with the longer studs. Buy the spacers from Andy (Bamachem).
Old Mar 6, 2005 | 04:38 PM
sschaefer3's Avatar
Your not ready for a lift. You need to understand what you are doing more.
Old Mar 7, 2005 | 09:22 AM
yea i kno im not going to get a lift soon im just trying to plan ahead....and learn some stuff
Old Mar 7, 2005 | 09:23 AM
I just am starting to get into all this so sorry if my questions are kinda stupid.
Old Mar 7, 2005 | 09:27 AM
bamachem's Avatar
we all have to start somewhere.
however, you have a ton of info at your fingertips. do a couple of searches and read all you can, then go back and read them again. you need to absorb the info and learn what's going on. when that's all said and done, then you can ask INFORMED QUESTIONS and get relevant answers. been there, done that. OME works. TUNDRA TRD works BETTER
Old Mar 7, 2005 | 09:34 AM
Ok thanks
Amer
3.4 Swaps
19
Jun 5, 2017 10:43 AM
DrZero
18
Jul 24, 2015 11:31 PM
akaphilly
Jul 9, 2015 02:27 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
karbin
Jul 5, 2015 11:37 PM
