My 1997 3.4 Liter 4 Runner Broke Down On Way To Work, Please Help!!!!!
Old Mar 3, 2005 | 04:55 AM
BOSTON4RUNNER's Avatar
1997 4Runner SR5 5 speed 3.4 Liter
good running condition, but on the highway it began to buck, then ran rough, seems to rev up clean in nuetral but under a load running very rough not taking the gas.
water temp is fine, oil level is fine, no vaccuum leaks, did have some slight popping out the back, mild mild backfire, also engine itself sounds fine, no crazy mechanical noises coming from the engine etc...
check engine light came on and even flashed quite a few times, I plan to pull the code in a little while as I work for a transit authority and the maintenance department has a nice OBDII scanner.
Please respond with your thoughts....I wonder if it is a frozen gas line? or bad gas was 15 degrees here last night, I never had such a problem, but maybe I do now?
Old Mar 3, 2005 | 04:57 AM
bamachem's Avatar
i had that happen one time. it was a loose apark plug wire. engine all of a sudden ran like crap, missed, sputtered, etc and threw a CEL.
Old Mar 3, 2005 | 05:15 AM
rimpainter.com's Avatar
Yeah, get that CEL for us. That will help a ton in the diagnosis.
*Edit* Ha ha, I beat you Jamie!
MTL_4runner's Avatar
Definately post the code number when you get it, but I would bet it was ignition related as well.
Old Mar 3, 2005 | 05:33 AM
I had to get it in and out of the shop quick
It says number 4 cylinder mis fire,,,,,wasnt able to grab the code,,,forgot
that coil pack fired two different cylinders, I would think if it was a bad coil pack would show two misfires, but that might not necessarily be the case
maybe could be due to the fact I probably havent done plugs in well, lets just say a long long time
215k on the truck now, hasnt seen plugs recently will throw them in tonight, then if that doesnt do it move on to coil pack
Old Mar 3, 2005 | 05:40 AM
hmmm also brings me to my next question, how often should plugs be changed in such a monster
and again my next does it seem, most often that people who are into cars, mechanics dont take better care of their own cars?
Old Mar 3, 2005 | 06:01 AM
I would change the plugs anyway unless you have done them very recently (I do mine every 35-45k).
You might also take a quick look at this (could be something to look at):
http://www.los-gatos.ca.us/davidbu/toyota.html
Here was the final culprit:
Could also be a coil pack so I would do a quick check on that as well.
Old Mar 3, 2005 | 06:19 AM
I did plug wires awhile back...as I had some misfires in the rain, wet weather
plugs,,,,,,um
should I say it
100k or so ago, maybe a tad more
are you guys going to burn me at the stake? put me in those wooden shackle things in the town square?
Old Mar 3, 2005 | 06:22 AM
this is me, after you guys are done with me
bamachem's Avatar
go get some from the dealer... about $1.75-$2 each. You'll need a ratchet w/ a long extension, a spark plug socket, and a 10mm socket to remove the coilpacks and the intake to the throttlebody. it will take you about 30-40 min to change them and get everything back together.
Old Mar 3, 2005 | 06:30 AM
yes I have done them before
thanks for the refresher though, has been awhile
been too bust working on this sh-tbox that my truck suffered plug failure
this one has fresh plugs
Old Mar 3, 2005 | 06:57 AM
roger's Avatar
I think mechanics take professional pride in making their vehicles run as long as possible with the least maintenance.
What kind of engine is that you're building?
Old Mar 3, 2005 | 08:22 AM
302 chevy, 650hp all together and running now
yeah so putting plugs in the Toy tonight,...
Old Mar 3, 2005 | 08:24 AM
I was gonna guess a 383 stroker.
Give us a pic if you get a really nasty plug in there or if it ends up being something else.
Old Mar 3, 2005 | 08:43 AM
I will and thanks alot to everyone
this forum is helpful to us all
when I get back form Costa Rica, I will add a page to my www.sfaboston.com website to outline the rear bumper build along with the lift and tires...in case it will be of help
I am betting on spark plugs, best case scenariio is that they have 60k on them, maybe ALOT more
Old Mar 3, 2005 | 08:45 AM
here is the 383 stroker..that we built..with a blower
going in my friends 69 Camaro
this also will have fresh spark plugs!
Old Mar 3, 2005 | 04:20 PM
FIXED!!!!
came home put plugs in, all the plugs looked good but the number 3 was nticebaly dark....but the OBD2 said the number 4 misfired, not 3
so maybe the mess up on 3 which indeed fired correctly, caused 4 to misfire
checked it on two different scanners
so it had Bosch plugs, took them out and swapped in new NGK
started the truck up, did the same thing sounded like absolute crap
pulled off number 3 plug wire,,,down near the end of the boot where it slides over the end of the sparg plug, even though you could not see a crack,,,halfway around the plug wire it was cracked
threw on a used plug wire I had, all set! will warranty the other wires
upon close inspection it looks as if there was adefect in the rubber/plastic sleeve that sits over the plug, almost like a rouch casting mark, or casting flaw you would see in cast iron, it definitely wasnt melted, the plug wire seems as if it was flawed at production
the wires have been in the truck for 5 months, guess it took that long for it to f-ck up this badly, but for awhile now I do think I had a very mild mis on the highway,,,probably a precursor to the final big crack and arc out
thanks again for the ideas and support
regards, tim
voiddweller
19
May 2, 2016 09:10 PM
torgeir
Jun 25, 2015 05:26 AM
gog1968
Jun 22, 2015 05:55 AM
Mack
May 17, 2012 08:57 AM
Corey
Jun 10, 2002 04:23 AM
