88' 3.0 V6 4-runner problem starting cold
Old Mar 2, 2005 | 09:52 PM
1badyota's Avatar
Has anyone else had any problems with starting their 4-runners when it is cold. This is the second truck that has done it to me. When it cold out it takes quite a few cranks than it should. when its warm out or after it ran and a little while later its fine. I dont drive the truck much at all. Any help would be greatly appreciated.
Old Mar 3, 2005 | 02:12 AM
DudeBud's Avatar
cold start injector or the temp senser for it sorry cant think of the name of it right now
Old Mar 4, 2005 | 07:58 PM
1badyota's Avatar
cool, thanks alot i will try it out
Old Apr 3, 2005 | 08:11 AM
YotaJunky's Avatar
Any luck with resolving the cold start problem? Just following up to compare notes with what appears to be sluggish cold starting in my '88 3.0L. I've got the same cold starting symptoms as you had described.
Troy
Old Apr 4, 2005 | 08:52 AM
braverex's Avatar
Me 2... Me 2... Got the same thing happening and am curious about a fix...
Old Apr 4, 2005 | 09:40 PM
me 3 me 3...let's have a party when we all get ours fixed.(although it'll probably turn out to be a different part for each of us...)
Old Apr 5, 2005 | 03:08 PM
YotaJunky's Avatar
bumpity...bump
Old Apr 5, 2005 | 08:26 PM
frankenrunner's Avatar
Guest
try removing & cleaning the cold start injector, then check the temperature sending unit &/or possibly replace it.
-f-
Old Apr 6, 2005 | 05:20 AM
YotaJunky's Avatar
Where is the temperature sending unit located?
TIA, Troy
Old Apr 14, 2005 | 08:28 AM
braverex's Avatar
Fix... Maybe...
I did some tinkering this weekend and so far for the past three days she has started right up in the mornings without excess cranking.... Maybe it is a fix? I don't know but worth a try...
In the following picture I have an arrow pointing at a bolt... This bolt has a hole and is hollow in the center. While I had it off I also noticed the presence of gasoline so :pat: the hole in the screw has to be aligned with the incoming gas line. For whatever reason mine had worked itself out of alignment. I marked the bolt head with a sharpie and tightened her back down but made made sure it was aligned properly. Now she seems to be starting like a champ again...
Old Apr 14, 2005 | 09:06 AM
89_4runner's Avatar
That bolt is for the fuel line running to the cold start injector. I doubt that the alignment is critical because there should be a groove inside the round section (bayonet) on the end of the hard fuel line. Maybe it was clogged and simply removing and replacing it did something.
Old Apr 14, 2005 | 09:44 AM
braverex's Avatar
That is definitely a possibility... doesn't take hardly anytime at all to take it out and make sure it is nice and clean!!!
Pay attention to the gaskets that are on it though... there is one on each side of the fuel line...
Old Apr 16, 2005 | 07:22 AM
1badyota's Avatar
http://replacement.autopartswarehous...ld+Start+Valve
this did the trick but you can get it way cheaper at advance or pep boys
Old Apr 16, 2005 | 07:55 AM
YotaJunky's Avatar
My cold start injector appeared to be clogged up. I removed it about a week ago and broke one of the mounting bolts!!:cry: Be very careful with how much torque you apply to the bolts. I was very, very lucky because I was able to remove the stud with an easy out.
Here's the link to my fiasco, which fortunately, worked out in my favour:
https://www.yotatech.com/forums/f16/broke-bolt-off-cold-starter-injector-mount-56481/
nvwiggins
13
Jun 16, 2016 03:05 PM
JHalcyonM
Sep 14, 2015 01:10 AM
sanctfy
Sep 13, 2015 06:33 PM
EatChipsNow
Sep 9, 2015 01:25 AM
seab1209
Sep 3, 2015 05:41 PM
