anyone else getting a clicking from their blower fan motor?
Old Feb 27, 2005 | 02:04 PM
f16fxr4real's Avatar
Whenever I turn the heat or air on the motor is making a distinct clicking sound. I've tried taking it out and cleaning it to no avail. Makes me wonder if I should just replace it.
Old Feb 27, 2005 | 02:40 PM
MTL_4runner's Avatar
Is it making contact with something up inside the duct?
A worn out motor doesn't usually "click".
Old Feb 27, 2005 | 07:18 PM
NorCalVP's Avatar
the fan in My Tercel does this, but i haven't taken it apart to look at it. I always thought that something was stuck in it.
Steve
Old Feb 27, 2005 | 07:20 PM
desert whomper's Avatar
its dirt in the switch mine did these about 3 weeks ago, i cleaned the switch and it works fine now.
Old Feb 27, 2005 | 07:33 PM
ttr125mar's Avatar
I just got done cleaning mine, a mouse nest was made above it and when I went to put recirculate on (drops the door) it fell right on my fan (killing the mouse).
Thanks,
Mario
Old Feb 28, 2005 | 04:11 AM
Thanks,
Mario
.....that must have smelled good.
Old Feb 28, 2005 | 08:39 AM
4Crawler's Avatar
You might have a look at the motor brushes:
http://www.4crawler.com/4x4/CheapTri...ml#MotorRepair
Old Feb 28, 2005 | 11:04 AM
02SE's Avatar
Thanks,
Mario
Murderer!.
Old Feb 28, 2005 | 11:45 AM
ttr125mar's Avatar
It didnt smell that bad, actually there was no smell. That mouse deserved it if he was in my truck with out my permission.
Thanks,
Mario
Old Feb 28, 2005 | 03:48 PM
SD70MAC's Avatar
Mine did that and I took out the fan to find 1 partially broken blade and a few pieces of pinestraw
Old Feb 28, 2005 | 06:19 PM
I took it all apart and......
There aren't any broken blades or anything and I think it may be the brushes. When I turn it by hand either way it always clicks in the same spot regardless of which way I turn it. I tried getting the white fan assembly off and I dont know what its on there with but I can't think of anyway to pry it without flexing that fan. Worried about breaking it.
Old Mar 1, 2005 | 05:04 AM
It does come off, I think I remember "Keisur" did it at one point.
If you did turn it by hand and it made a sound that is a pretty good clue where to look (most assumed you would have mentioned this).
Once you get the fan off, the motor is easy to take apart.
I assume you saw this as well already:
http://www.4runners.org/articles/fan/
Here is the original big thread on fan ticking:
https://www.yotatech.com/forums/show...hlight=ticking
Old Mar 1, 2005 | 09:27 AM
yes I saw both those posts
Although now after rereading again see how to pull the motor out of the housing. Don't know how I missed that before. Will it come out with the fan still attached to the front? And what about the contactors where the pkug goes in? Do those come out with the motor?
Old Mar 1, 2005 | 10:13 AM
Yes, mine came out with the fan still attached, the connector comes out with the motor as well.
SubiKing
Aug 21, 2021 03:57 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
94yotaky
Jul 23, 2015 07:50 AM
msane99
Jul 17, 2015 10:13 AM
cars-guy
Jul 11, 2015 07:51 PM
