Spring over axle?
Old Jan 17, 2005 | 08:07 AM
Tacoma750's Avatar
Spring over axle?
How is it done?And what are the benifits? of a spring over axle..SOA
Old Jan 17, 2005 | 08:46 AM
jacksonpt's Avatar
Senior Member
What vehicle is it being done to. I'm sure there are differences based on the vehicle, but in general terms, the springs are re-located to the top of the axle, the knuckles are cut, turned, and welded back in place. It's generally recommended to go to a hi-steer setup.
Benefits are that you continue using the soft stock springs, which usually allow for more/easier flex than stiffer lift springs.
Old Jan 17, 2005 | 09:34 AM
Adam F's Avatar
All 4x4 Toyota pickup trucks and 4Runners were sprung OVER axle from the factory. The only ones that were sprung UNDER are Land Cruisers.
I don't think you really HAVE to cut and turn the knuckles unless you want, but you HAVE to cut and relocate the spring perches.
Old Jan 17, 2005 | 09:39 AM
jacksonpt's Avatar
Senior Member
ah, that I didn't know.
Yes, technically you don't HAVE to turn the knuckles, but it's very highly recommended.
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
nvdesertrunner
May 11, 2020 08:18 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
priest16
15
Aug 6, 2015 07:43 AM
