another diff fluid question
Old Jan 1, 2005 | 11:17 PM
Localmotion's Avatar
I have 190k on my 1996 4runner. I dont ever remember chaning the diff fluid on it. Would it be wise to change over to synthetic at this point? and if so, is there anything i need to do differently when changing to synthetic?
Matt
Old Jan 1, 2005 | 11:21 PM
jimbo74's Avatar
changing to synthetic is always a good thing... unless you have a leaky diff currently, there is no problems and you will be fine....
Old Jan 1, 2005 | 11:28 PM
kevin444's Avatar
I cant get the diff drain bolt off. I dont have a 24mm combo wrench.
Old Jan 1, 2005 | 11:29 PM
i checked the rear diff and it seems that its not leaking. i think the pinion seal is leaking? thats what a buddy of mine told me i checked my extended diff breather and everything was fine. any ideas on why its leaking?
thanks
Matt
Old Jan 1, 2005 | 11:31 PM
superjoe83's Avatar
go buy a 24mm socket, its pretty hard to get a boxed or open ended wrench on the drain bolt because of the guard, if your in a pinch, a 15/16" socket will work
Old Jan 1, 2005 | 11:33 PM
superjoe83's Avatar
Matt
you may be OK going to synthetic, when i changed to synthetic in my diffs, the rear pinion seal seeped for awhile, but currently has stopped, its hard to tell what your leak may do
Old Jan 1, 2005 | 11:38 PM
i guess theres only one way to find out! from what ive heard, it isnt that expensive to get the pinion seal replaced. Thanks
Matt
Old Jan 1, 2005 | 11:44 PM
kevin444's Avatar
I have a 24mm socket apparently i cant put enough torque and im kinda stripping the drain bolt. Im scared of stripping it anymore. So im going to look for a combo wrench.
Old Jan 1, 2005 | 11:49 PM
jimbo74's Avatar
try heating it up wti ha torch or try shooting it with pb blaster.... both would probably help.. if you are jsut rounding off the head, you are getting enough torque, more than the head will allow....
Old Jan 1, 2005 | 11:52 PM
kevin444's Avatar
Im going to grab some pb blaster. Cuz it seems wd40 aint doing its job.
Old Jan 1, 2005 | 11:55 PM
SolidDigital's Avatar
if you have a 15/16th inch socket try that, its a bit smaller than a 24mm and is less likely to strip it.
jimbo74's Avatar
seriously wd40 sucks... pb blaster is much better.... wd40 is mroe of a solvent than a real penetrant
Old Jan 2, 2005 | 12:13 AM
kyle_22r's Avatar
you need a 6 point. trust me, every time i try to break one of these 25 year old drain/fill plugs, they strip. stupid design, there's no meat to grab onto.
if you strip one badly, the best way to go is get a chisel and a hammer and try to break it loose that way. after that, upgrade to the plugs that take an allen wrench rather than a socket...i can't remember the part # off the top of my head
Old Jan 2, 2005 | 12:54 AM
jimbo74's Avatar
From Marlin Crawler
Low Profile Magnetic Drain Plugs
These factory replacement drain plugs feature a built in magnet to help remove metal filings that accumulate during normal use. The much smaller, round head design reduces chances of rocks grabbing edges and loosening plugs while on the trail. Requires 10mm Allen socket to install or remove. Low Profile Magnetic Drain Plugs $4 (each)
Old Jan 2, 2005 | 04:15 AM
shovelhead's Avatar
Hit the drain plug with a hammer (like you were trying to drive it in to the rearend housing) Don't get crazy just strike it sharply that should free up the plug
Old Jan 2, 2005 | 04:31 AM
jimbo74's Avatar
also i agree about the 6 point socket.....
Old Jan 2, 2005 | 04:46 PM
leebee's Avatar
dont forget to change the crush washers while youre at it. they are cheap and will ensure a good seal, torque to spec and you are good to go. jim, those allen head plugs are a great idea, im going to find some to replace on mine.
lee
Old Jan 2, 2005 | 05:19 PM
jimbo74's Avatar
it was kyle 22r's idea... in his post just above mine... however it was me who remebered where i saw them
krimsonone
Sep 13, 2024 09:33 AM
jaretstuff
Aug 4, 2015 02:08 PM
Athansinis
Jul 27, 2015 08:38 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
scottyg486
Jul 19, 2015 05:34 PM
