how to chang to synthetic oil?
Old Dec 13, 2004 | 02:14 PM
yotaluver's Avatar
ok i want to start using synthetic oil what do i need to do? just chang the oil and filter? or do i need to flush the engine or what? what kind of filter should i use?
Old Dec 13, 2004 | 02:20 PM
Tacoma Dude's Avatar
Amsoil says to flush your engine before changing over - I drained old dino out put in new synthetic and switched out the synthetic after 3K. Been running Amsoil since (about 40K) with no problems.
Old Dec 13, 2004 | 02:28 PM
toyotanut3717's Avatar
No you don't have to flush the engine, just change the oil and filter. I would go with Mobil 1.
Old Dec 13, 2004 | 02:45 PM
User 051420's Avatar
As per Amsoil's recommendation, I flused with their Engine Flush first. I think it's a good idea; and not that expensive.
Old Dec 13, 2004 | 04:30 PM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
You may want to do a search on this topic. There are those that believe that switching over a high mileage vehicle from dino to synthetic is not a good idea.
Old Dec 13, 2004 | 04:38 PM
I did at ~170k miles.
Old Dec 13, 2004 | 04:56 PM
gwhayduke's Avatar
1. Remove drain plug, drain old oil.
2. Replace plug
3. Remove old oil filter
4. Clean gasket surface
5. Smear a film of oil on the new oil filter gasket
6. Install oil filter hand tight.
7. Fill crankcase with correct volume of synthetic oil
8. Drive 5,000 miles
9. Repeat.
I've changed over at high mileages (98,000 miles) and lower mileages (60,000 miles). My wife can tell a difference in which oil is in the vehicle, though she never knows what I've done. She likes the way the engine feels with synthetic and the '95 4Runner gets about 1 mpg better on it. Can't wait to get it in '99 crankcase as well as the diff, tranny and transfer case.
Old Dec 13, 2004 | 05:17 PM
yotaluver's Avatar
are you glad you did?
Old Dec 13, 2004 | 05:20 PM
Yep! My engine runs quieter, and smoother. I have the piece of mine that Amsoil is protecting my engine. I had the oil analyzed by Blackstone after 10k miles, and everything was in pretty good shape. I'm on my second round of Amsoil right now. I'll change my oil about 3 times a year now, instead of every month.
I have my mom running it in her 97 Infiniti QX4 also. It too runs MUCH quieter.
If you have questions, check out Gadgets page on oil; he has some great insight.
Old Dec 13, 2004 | 05:32 PM
96LtdYota's Avatar
is the chang a new dance?
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
HRDC0R19
Jul 5, 2015 06:43 PM
