synthetic tranny fluid at 120k a good idea?
I have a 1996 4Runner with 120k on it. I am going to be changing the tranny fluid and I want to use the Redline MT-90 which is synthetic. Should I have any concern about using synthetic on my high mileage truck? I have mainly heard in regards to engine oil that the synthetic oil has a tendancy to find weak spots in seals due to its finner properties. Does that also go for tranny fluid? Currently I have no leaks on my truck.
Are you refering to engine oil or tranny fluid? I think as far as engine oil goes I am not balsy enough to switch just because dino has been working and I think I will stick with it. But as far as the transmission and differential, I would like to get those on synthetics.
Originally Posted by 4Runner4Christ
If your engine has been properly maintained and has no signs of leaks you can start using synthetics. I would suggest Amsoil XL7500 after doing the Amsoil engine flush thing.
Originally Posted by FilthyRich
if your truck has a bunch of miles, synthetic engine oil can only benefit you. IMO. I run Amsoil synthetic everything and I have 97k miles.
Nolan, I swithced over to Amsoil for my transmission and diffs/t-case when I bought my truck. Still using dino for the engine. It had 110,000 miles on it when I bought it. I have not had any problems.
I did, however, drain the Amsoil from the transmission and switch over to the Redline MT-90 since my shifting was not that great with the Amsoil. I have been pretty happy with the Redline in the transmission and I guess the Amsoil is doing OK in the diffs and transfer case.
Jnkml
Jul 6, 2015 01:20 PM
