rear drive shaft woes
Old Dec 8, 2004 | 08:34 PM
supahonkey's Avatar
I am damn near complete with my SAS on my 02 tacoma, and as I went for a little test drive after replacing the brake master cylinder with a larger one, my rear drive shaft came out of the yoke. I am using 3.5" rear blocks with the stock toy rear axle. The yoke came out of the splined shaft as soon as I gave it some gas, so the axle wrap must have been bad enough to cause it to come out. Now, when I put the yoke and the shaft next to each other, the shaft is only going into the yoke about 3/4". Of all of the writeups I've read on SAS's, I've never seen anyone having to replace their rear driveshaft. Because my rear is sitting about 1-2" too high, I could cut the blocks down (I would love to b/c I hate lift blocks with a passion) but after doing the math, I would only create around 1/2" of extra drive shaft length in the yoke. I can't think of what I"m doing wrong. I don't have the money for a new rear drive shaft, but I need to get this going because I"ve been without my truck for a week now. What do you think about getting the rear drive shaft lengthened? anyway, thanks.
brenton
Old Dec 9, 2004 | 08:48 AM
4Crawler's Avatar
Axle wrap tips the pinion up, not down, could have been backing off the gas popped the slip yoke out. Is your driveshaft a 1-piece or 2-piece (center support bearing) type? If the latter, do your blocks have a bevel to them to tip the pinion up for the proper shaft alignment? If not, that will help a little. Its not terribly expensive to have a shaft lengthened, check with your local driveshaft shop. Also consider having it re-tubed with heavier wall stock. The OEM tubing is not up to a lot of trail abuse.
Jun 1, 2021 01:51 PM
Jdgarrison
Oct 1, 2015 05:22 PM
icentropy
Jul 11, 2015 07:21 AM
Jnkml
Jul 6, 2015 01:20 PM
toyoda8488
Jul 5, 2015 10:18 PM
