Emergency Bracke Comes on, Then Goes off. Ideas??
Old Nov 8, 2004 | 08:06 PM
toyturbo's Avatar
Talking Emergency Brake light Comes on, Then Goes off. Ideas??
86' truck here!
I come to a stop and the light comes on.
I take off, and the light goes off.
Stop again, it comes on!
Any ideas??????????????
I just took out my dash to replace the heater core. I found an old clifford alarm system, so removed it all, and did some re-wiring.
Don't think I crossed any wires!
Tried to un-hook pos. battery cable to see if the electronics would reset it self.
Didn't work.
Any ideas???????????? :pat:
-Kyle
Old Nov 8, 2004 | 08:10 PM
jimbo74's Avatar
your brake fluid reservoir is low on fluid
Old Nov 8, 2004 | 08:11 PM
apaka's Avatar
maybe your e-brake cable is loose and the common stop and go situation would move the lever in the cab. There's a push button sensor there that turns on and off the e-brake light. Next time it comes on...push the e-brake in and see if your light turns off...if so, check your e-brake line...it's not tight.
i drive an '84 so it might be different on your rig...then again maybe not. My e-brakes are seized in my rear drums...which appears to be a common problem i'm noticing. So my cable is disconnected and my light comes on time to time...i just push the lever in and the light turns off.
hope this is your problem...cause this has to be the most simplistic check/diagnostic ever.
Old Nov 8, 2004 | 08:12 PM
apaka's Avatar
what exactly does his brake fluid resevoir have to do with a cable driven emergency brake?
Old Nov 8, 2004 | 08:14 PM
toyturbo's Avatar
I will check it out tomorrow.
Thanks.
-Kyle
Old Nov 8, 2004 | 09:27 PM
Nix_Toy's Avatar
The brake light comes on when the emergency brack is on, or if your brake fluid is low.
Old Nov 8, 2004 | 09:43 PM
apaka's Avatar
oh...i always wondered why there was a sensor in the resevoir.
good to know.
Old Nov 10, 2004 | 10:55 AM
mtnfreak's Avatar
How many volts are you getting out of the alternator at idle? My truck was doing this just before the alternator died. Don't know why the brake light comes on instead of the ALT or the CE light, but Toyota wiring has always confused me.
Old Nov 10, 2004 | 12:50 PM
toyturbo's Avatar
I think I found the problem.
I have a normal and power buttons, neither were engage.
Pushed the normal and the brake light hasn't come on anymore.
Still keeping on I on it.
Thanks for the ideas.
okamikai
Apr 30, 2018 10:19 PM
raptor510
Feb 17, 2017 07:11 AM
KBar
Aug 3, 2015 05:14 PM
nonstop
Jul 24, 2015 06:29 PM
PlayAwhile
Jul 20, 2015 11:36 AM
