3vze electrical ?! timing prob
Ok guys, this one has been driving me nuts. I need some serious help.
What I have:
1989 Toy 2x4, xcab, SR5, V6, (3vze), AC, cruise, PPS (progressive power steering.) The engine has just been rebuilt.
I have a copy of the factory service manual.
The problem:
When trying to set the timing I can not get the engine to ‘kick down’ by jumping the test points.
What I’ve done:
Checked and replaced the temp sensor. It works and the engine kicks down when warmed up.
New TPS.
MAF tests fine
I have and have tried a newer ECU and it acts the same with either.
AC and PPS idle up circuit unplugged.
Distributor tested fine. There was one wire in the harness that originally was open, but it has been fixed.
I’ve had the wiring harness out and have tested a good portion of it point to point.
I’ve run through the factory service manual and have tested the ECU point to point and every number comes out right except for IDL to E2 is low @ about 4 volts.
I am assuming that this is an electrical problem as there is something over riding the test circuit.
Any ideas, help or abuse appreciated.
What I have:
The problem:
What I’ve done:
New TPS.
MAF tests fine
What I have:
The problem:
What I’ve done:
New TPS.
MAF tests fine
What I have:
The problem:
What I’ve done:
New TPS.
MAF tests fine
Originally Posted by nunsa
You said that "when the engine is warmed up it kicks down" Thus, you don't have a problem if it's warmed up and she kicks down! You should be checking your timing w/a warmed up engine and the diag. connector jumped. If when warm it doesn't kick down it's usually your TPS but you said you replaced your TPS, did you spec it out w/a multimeter? Could be your wiring of the TPS not necc. your TPS. Good Luck!
When jumpered at the test terminals (engine warm) the dash check engine light flases an 'ok' code BUT the idle timing does not change. I can not adjust it under +10 degrees. I have set the distibutor back one cog, but this does not help. I am guessing that I am missing a mssed up circuit that over rides the timing. I have unplugged the AC and PPS (progressive power steering)cicuits. I do not know where else to check.
:pat:
Recheck the TPS, only measure the resistance at the TPS itself. You need to have the IDL-E2 setting within spec to make the ECU aware that you are at idle:
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
I am a newbee to the forum, but not to beatin Yotas into submission. My professional mechanic friends scratch their heads at this one, too.
I was just hoping that somebody in cyberland had an idea that would spark a solution. THX
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
Sep 9, 2015 06:24 AM
