Spedo Jittering?
Old Oct 27, 2004 | 02:46 AM
Krash's Avatar
Spedo Jittering?
I did a quick search and didn't find alot on it.
Here's my prob, I'm going down the road and my speedo is jittering like shaking erratically. I'm not hitting any bumps, at least not ones to cause this kind of jittering. I mainly notice it inbetween 45 and 75. Has anyone else had these problems? I just want to get a head start on fixing it before it gets rediculusly cold.
Old Oct 27, 2004 | 02:55 AM
4-RUNNIN' FREAK's Avatar
Does it sputter? Mine just started acting up again today and the speedo jumps just a little though and I lose power and it comes back lose it again and it comes back plus the pinging is worse than ever. Seems to be after I had to unplug the battery for 2 days. Maybe the 47 psi in the tires I just put in is doing it
Old Oct 27, 2004 | 04:01 AM
Corey's Avatar
Co-Founder/Administrator
The cable is dry.
All '89 and up to whenever before they switched to a cableless one do this.
Mine now for the 1st few minutes during these cold mornings groans real loud.
The sound is enough to make you want to put in ear plugs.
The cure is to pull the cable out and lube it, or have the dealer replace it.
I learn to live with it.
Old Oct 27, 2004 | 04:53 AM
HondaTec521's Avatar
I think i'll try lubin' mine.Thanks!
Old Oct 27, 2004 | 11:20 AM
Krash's Avatar
Thanks corey, man I was thinking that the gears on it were going out or something worse. I'll live with it till I get the time to mess with it.
Old Oct 27, 2004 | 12:36 PM
hektikwon's Avatar
mine does the same but no noise. I bought a new cable from tha stealership ($78!!!) but that didn't solve it. so I live with it
Old Oct 27, 2004 | 03:09 PM
Yamaha+Toyota=Fun's Avatar
Could be a loose guage cluster, mine was loose my truck and it made my speedo and tach jump around a little bit.
Old Oct 27, 2004 | 03:11 PM
Krash's Avatar
see my tach doesn't jump though just my speedo. I think its the cable that is loose or something. I'll mess with it in a couple weeks when I get the time.
Old Oct 27, 2004 | 05:20 PM
Corey's Avatar
I should shoot a video when I leave for work so you can see what I put up with when it is cold outside.
Old Oct 27, 2004 | 05:38 PM
Krash's Avatar
man thats alright, when it rains my dome light will turn on when I open the door, any other time it doesn't want to work or will work when it wants to.
Old Oct 27, 2004 | 06:39 PM
Epic Ed's Avatar
Did someone say "speedometer cable problems?" Oh, yeah -- I've seen it all on my 2nd gen. My problems started after I put on headers -- melted through two cables before re-routing it far enough that the sheath doesn't turn to soup. The third time it happened I replaced the plastic gear going into the transfer case at the end of the speedo cable that was stripped. Did that the fourth time, too. The fifth time -- did I mention this was all in the past three months? -- we replaced the gauge cluster. It's been two weeks. No shaking, jittering, or jumping so far. Each time it failed, it had the symptoms you describe right before it failed.
It may be dry and in need of some lube, or it may be shot and ready for replacement. Or it could be a siezed up gear in the gauge cluster. My suggestion is to take action soon. Fortunately, if it does go, it doesn't prevent you from driving the vehicle. The computer will toss out a check engine light, and the O/D light wil flash on/off, but you can at least keep motoring.
Hope you have better luck than me.
Ed
Old Oct 27, 2004 | 07:55 PM
yotafreakshow's Avatar
I have Corey's problem as well, a LOUD screeching groan on cold days. I have to pull out the speedo and lube the cable good every winter. Should go out and do it now before it gets any colder...I'll never learn.
Needle bounces around pretty good too.
Old Oct 27, 2004 | 09:03 PM
SolidDigital's Avatar
does it do it only when you move or when you're stopped and rev it too? mine might do it also
Old Oct 27, 2004 | 09:28 PM
ChickenLover's Avatar
Mine does the same thing, first thing in the morning on these cold days as soon as I reach about 55mph. It groans, but not as loud as yours seems to. It goes away after a few minutes. Pretty annoying to say the least.
Old Oct 28, 2004 | 01:25 AM
Krash's Avatar
well worse comes to worse i still have my crappy 3 gauge cluster from the swap. I'll lube it here soon just my next two weekends are extremly busy that I wont have the time to do it.
Old Oct 28, 2004 | 02:36 AM
Corey's Avatar
Only when moving, and it can start in at 10 MPH all the way up to whatever.
It can do it for 5 minutes or more, then it stops.
I will never pull it out and lube it, so I live with it.
Old Oct 28, 2004 | 04:16 AM
Krash's Avatar
Little stubborn are we?
Old Oct 28, 2004 | 05:13 AM
All you have to do is pull off the outer trim piece around the guages pull a few screws and the guages fall out into your lap. The cable disconnects easily. I had to do mine twice the first time becuase I didn't work the lube in there as well as I should have. I bet if the cable were also disconnected at the TC it would pull out of the sheath a bit to make it easier. It seems like there is a seal you have to work the lube past to get it in the area that squeals and drives me nuts.
Old Dec 19, 2004 | 10:27 PM
I had the rear flange come loose on the back of the transfer case which damaged the plastic gear on the speedo unit coming out the transfer, replaced it with a used one and it seems to work fine so far. First noticed the speedo shake at about 45/50mph and wouldn't really go above 65......... then the vibration started on deceleration. Dropped the driveshaft and out came the transfer oil from around the flange nut. Hopefully it didn't damage anything else?!?!?
Old Dec 19, 2004 | 10:42 PM
Krash's Avatar
Well my speedo still jitters but its nothing really bothering me that much. I got the squealing to go away with wd-40. I dunno how good that is. Probably isn't good but it was a quick fix because it was cold and I was just using it to get rid of the noise over the winter.
