Body lift gap covers...where to buy?
Old Oct 11, 2004 | 02:25 PM
BajaRunner's Avatar
Putting a 2" BL on soon...well, once I get the money.
But before I buy it and install it, I would like to get some gap guards. I hate that look of seeing through the frame and body.
What can I use? I was thinking some sort of black plastic/rubber stuff that I can either glue on or bolt on.
What are you guys using? I havent heard much about it.
Thanks!
Old Oct 11, 2004 | 03:46 PM
User 051420's Avatar
Pond liner is supposed to work well. Some company makes these commercially, try a search..I think it was brought up a while back.
Old Oct 11, 2004 | 04:12 PM
4Crawler's Avatar
Yes either make your own or try Lift Lips, I have a link to their page off of my body lift page.
Old Oct 11, 2004 | 05:57 PM
cool rob's Avatar
I used floor liner material from Home Depot...cheap and durable.
Old Oct 11, 2004 | 06:12 PM
Arnold's Avatar
I used shower liner from Lowe's and paid just under $15.
Old Oct 11, 2004 | 07:49 PM
Birdman's Avatar
I bought some rubber sheet at OSH and used my old gap liners as a template for making some new ones. The two sides are the same on mine so once I had one side cut out, I traced out the second. I reused the snaps and stock holes. This took me about an hour to complete. Looks much better this way. The sheet below was $10.00.
Old Oct 12, 2004 | 02:22 AM
Bigkahuna808's Avatar
Time to hit home depot and go on a scavanger hunt for thoes things.
Old Oct 12, 2004 | 03:19 AM
mt_goat's Avatar
Thanks!
I made these out of a sheet of 1/8 inch buna rubber.
http://community.webshots.com/photo/...71947295nKgvpi
http://community.webshots.com/photo/...71947202hNLrgO
Buna rubber is oil resistant.
Old Oct 12, 2004 | 08:53 AM
where did you get the buna rubber?
Old Oct 12, 2004 | 09:49 AM
mt_goat's Avatar
These guys: http://www.rgausa.com/
They have a local warehouse here in OKC that I found in the yellow pages under "Rubber Products"
RGA (Rubber & Gasket Co. of America)
4401 Southwest 44th
Oklahoma City, Ok 73119
(405)688-8100
Old Mar 23, 2005 | 10:56 PM
photoleif's Avatar
I just did the Home Depot thing tonight and got a bunch of black runner for under $20. The part number, which may work on their website if someone wants to look it up, is 808987. Unfortunately it's 27" wide, which was easily wide enough for two "lips" for me, but no more... so I needed quite a bit of it in the length -- around 7 feet for the full-blown "lips" I wanted to do.
I carefully removed the stock plastic clips from the front (and got sore fingers to prove it), removed and traced the outline of the stock rubber shields, and enlarged them in the width and length to fit the new dimensions I wanted. I found that a paper-punch worked perfectly for making the holes. I'm embarrassed to say I tried making one hole with a 1/4" forstner bit... that was a mess. The runner is lightly textured on one side and ribbed on the other, and is tear-resistant and plenty tough and flexible. It doesn't collapse or become abraded by tightening a bolt against it. It far outstrips pool liner, vinyl or other sheet plastic. Definitely good stuff.
Old Mar 24, 2005 | 04:06 AM
93ToyKid's Avatar
I used the floor liner like they put on buses. I know a guy who works at Thomas built buses (I live about ten minutes from their MASSIVE manufacturing plant), so he hooked me up. I just made a template out of cardboard and used self-tapping sheet metal screws to secure it. I'll try and snap some pics this afternoon.
Old Mar 24, 2005 | 05:11 AM
bamachem's Avatar
use buna-n rubber.
available from http://www.mcmaster-carr.com
Old Mar 24, 2005 | 05:33 AM
mt_goat's Avatar
Originally Posted by bamachem
use buna-n rubber.
The link doesn't work for me.
Old Mar 24, 2005 | 05:40 AM
bamachem's Avatar
also try: http://www.mcmaster.com/
catalog page 3279...
Old Mar 24, 2005 | 06:31 AM
mt_goat's Avatar
Yeah, that one works. I love that catalog. I used the 1/8 inch thick for mine, glad I did too because it is starting to crack a little bit around the bolt holes and any thinner might be tearing soon.
Old Jul 20, 2005 | 07:14 PM
Ric's Avatar
Ric
Banned - User requested
hey all,
those of you that did something to the BL gap, could ya let me know how that stuff is holding up ? and let me know what ya used.
Thankx
Old Jul 20, 2005 | 08:19 PM
sschaefer3's Avatar
Originally Posted by Ric
hey all,
Thankx
Dana 44 covers and doing fine months later.
Old Jul 20, 2005 | 08:26 PM
4Crawler's Avatar
I've been running the same set of Lift Lips for the last 7 years, still working fine.
Old Jul 21, 2005 | 11:47 AM
Flamedx4's Avatar
Here's tip for those trying to poke holes in rubber and the like. When I did my mud flaps (easily 5/16" thick) here is how I punched holes. I scrounged around and found a piece of steel tube with about 5/16" inner diam. I think it was the sleeve from an old shock mount or suspension bushing or something. I ran it against the grinding wheel, turning it around all the time, so that one end is now a sharp hollow punch. Then place the rubber on a block of wood, hold the punch in place - whack with hammer. Perfect holes. (Learned this years ago when making up full width mud flaps for motor homes...)
