Opinion: Greasing CV Joints and boots
Greetings,
I have a 2001 Ex Cab Tacoma with about 32000 miles. I was talking to a buddy the other day and during the conversation greasing the CV Joints came up.
He stated that he has 106,000 miles on the CV joints in his truck because he greases them yearly. He told me he cut the steel band years ago and uses a wide wire tie instead. Once a year he cuts the wire tie, gently pulls the boot off the axle, slides a small air hose modified to attach to a grease gun and then pumps in a few ounces of water proof grease into the boot. He then uses another wire tie to seal the boot back to the axle.
Do they really need to be greased, and if they do, is this a better way then removing the axles? He also stated he has not had to replace the boots yet either. I went and looked under the truck and everything looks really good?
SOunds like a good plan, any thoughts?
MvCrash
MvCrash
Originally Posted by MvCrash
Greetings,
MvCrash
MvCrash
Good Luck !
* Harry *
kawazx636
Oct 6, 2021 03:03 PM
FS[MidWest]: 1.5" ball joint spacers
4x4YOTA
Aug 23, 2016 09:08 AM
FS[SouthCent]: TX - 4Crawler Ball Joint spacers
crash813
Sep 27, 2015 07:15 AM
Odin
Sep 26, 2015 06:56 PM
