MAF Sensor cleaning
Old Aug 16, 2004 | 05:40 PM
Jeffires's Avatar
MAF Sensor cleaning
After reading about the TB cleaning with Seafoam, I found some today and cleaned mine in my 3.0 by pouring it into the brake booster vacuum hose. I also got some electric parts non-residual cleaner and sprayed some into the MAF sensor under the lid of the airbox. The cleaner said it left no residuals and was safe for plastic, but now, a few hours later, I have having terrible idle that still produces black smoke (I guess its running rich). How long does it take for the MAF sensor to go back to normal? Do I need to remove it and do something else to it?
Thanks, Jeff
Old Aug 16, 2004 | 05:46 PM
CMD93's Avatar
Maybe try resetting your computer???
Do this by disconnecting the negative terminal on the battery for ~10 minutes or so.
Just an idea.
Chris
Old Aug 16, 2004 | 05:58 PM
Jeffires's Avatar
After 1 hour it was still bad, but I just got back from town and after another hour or so, it cranked like it did back in '91. Thanks anyway....
Old Aug 16, 2004 | 06:01 PM
blink's Avatar
you are getting black smoke?!
Old Aug 16, 2004 | 06:35 PM
Jeffires's Avatar
smoke
I was, but it was from the cleaning I did. I used seafoam in the vacuum and then sprayed the intake real good with a can of TB cleaner. That is what caused the black exhaust I think.
Old Aug 16, 2004 | 06:39 PM
blink's Avatar
mine was more white then black but it took about 10 minutes of idle and 10 minutes of driving to finally clear all the smoke and restore my idle. Also after i ran seafoam i switchedo ut the spark plugs cause they got wicked filthy after the treatment of seafom. goodluck!
Old Aug 16, 2004 | 06:40 PM
blink's Avatar
dood nm im dumb i read your post wrong
Old Aug 16, 2004 | 06:44 PM
Jeffires's Avatar
Thats cool- the seafoam did smoke white- wish i would have had the camera. I was in a classy neighborhood too Everythings back to normal now....
Old Aug 16, 2004 | 06:48 PM
blink's Avatar
Unhappy
haha... i had about 3 neighbors run out with there phones ready to dial the local fire department....
krimsonone
Sep 13, 2024 09:33 AM
smthwsn357
May 1, 2024 07:28 AM
montanatruck
Feb 26, 2017 07:07 AM
Tacoma1313
Aug 17, 2015 05:44 PM
redneck17
Aug 12, 2015 08:15 PM
