Hard Start 3.0 Urgent
this starting is getting very old
when cold the truck starts easy but then abotu dies when you give it gas and it hesistates when giving it gas until it warms up
once its warm the truck takes atleast 5 cranks to start but it always starts
i replaced the starter contacts and i think it helped a little bit with warm start
i show no codes and it runs great when warm
could having my exhaust cut off after muffler cause the bad running?
Obviously you want to ensure all the basic maintenance is done on the truck (plugs, cap, rotor, fuel filter, air filter, clean throttle body, adjust timing, etc). Next you should thoroughly check the fuel and electrical systems to ensure they are working properly (fuel pressure, battery voltage, alt voltage, etc).
Originally Posted by patterson
im thinking since my exhaust is cut off and it leaks be4 the cat its casuing the o2 to mess up
Consider first option to replace EFI relay's.
Primary relay under hood and 2nd relay under dash left of heater core.
It's a know problem that older 89-95 and some older models suffer from relay contact corrosion.
