Installed deck plate truck won't start
After putting the deck plate in the truck it won't start. I washed out the air box with water. I'm assuming that getting the Mas Flow Sensor didn't help. Anybody had this problem?
Originally Posted by Bob_98SR5
you washed your MAF?
also, did you pull the EFI fuse? if so, plug it back in and try again.
bob
bob
Some of the writeups when dealing with your intake say to pull the EFI 15A fuse out helps reset the computer to get used to the new airflow... He was making sure you put it back in if you had pulled it out in the first place.
Sounds like you didnt, but, that wouldnt cause your engine not to start.
Let your MAF dry out over night. Unplug it and make sure its dry before starting it back up.
scary stuff...
scary stuff...
From: Far western Kentucky (transplanted from central PA)
Originally Posted by cobrahunter
...I washed out the air box with water. I'm assuming that getting the Mas Flow Sensor didn't help...
From: Bend, Oregon. 4mer Teufelhund, now a DoD Contractor
Does anyone know of a pin to pin ohm out procedure to see if he is still within specific resistance tolerances? Unless I'm way off base I'm thinking that sensor is just a coiled transducer circuit with a specific range of ohms that can be measure and checked for continuity. I also assume that it's possible to open up the maf and inspect it for moisture or allow it to dry if necessary.
Most MAFs are just a hotwire setup so a simple resistanve check should work fine. I doubt just getting water on the sensor will kill it and even then the truck should start but just run crappy......my bet would be something else (make sure you plugged the MAF back in correctly if you did disconnect it).
88Toy
7
Jun 17, 2015 09:40 AM
