No start after knock sensor replacement
i replaced my knock sensor and now my truck wont start
its a 90 toyota 4x4 v6
its getting spark from the coil and from the plugs and its getting fuel
so the coil is good
would the ignitor poissibly be bad
i dont know if maybe the timing belt got off track from having to remove the belt spinner between the two camshaft pullies?
any help is great as i dont want to take it somewhere
it turns but doesnt start up
and also is the mass air flow sensor supoose to make a tap tap noise when trying to start
so the coil is good
Did you try putting the old sensor back on and try starting it?
You might have a bad sensor, or some of the wiring got crossed, loose or cut during the swap.
I would double check all of your connections.
voiddweller
19
May 2, 2016 09:10 PM
