No start after knock sensor replacement
Old Aug 1, 2004 | 01:59 PM
patterson's Avatar
i replaced my knock sensor and now my truck wont start
its a 90 toyota 4x4 v6
its getting spark from the coil and from the plugs and its getting fuel
so the coil is good
would the ignitor poissibly be bad
i dont know if maybe the timing belt got off track from having to remove the belt spinner between the two camshaft pullies?
any help is great as i dont want to take it somewhere
it turns but doesnt start up
and also is the mass air flow sensor supoose to make a tap tap noise when trying to start
Old Aug 1, 2004 | 10:39 PM
patterson's Avatar
need help please
Old Aug 2, 2004 | 03:58 AM
LX302's Avatar
Did you try putting the old sensor back on and try starting it?
You might have a bad sensor, or some of the wiring got crossed, loose or cut during the swap.
I would double check all of your connections.
voiddweller
19
May 2, 2016 09:10 PM
serenity03k64
Jun 27, 2015 07:59 AM
Bru
Jun 23, 2015 06:58 PM
Mutinebullfrog
Jun 18, 2015 01:36 PM
bobbybouche
Jun 18, 2015 10:22 AM
