jury-rigging extremeaire compressor
Old Jul 8, 2004 | 09:13 AM
Scottiac's Avatar
Question jury-rigging extremeaire compressor
I've got an extremeaire hardmount I've never gotten around to setting up, but I want to have air available this weekend. I don't have the time to figure out the mounting, get all the parts, move stuff around in the bay and all that to do it right.
What I want to do for right now is grab the parts needed to be able to use it as a portable. I don't have a tank (well, I don't have *anything* but the compressor right now).
So what I think I need is a way to get power from the battery to the compressor leads, a polyurethane air hose, and a flow through air chuck so I can leave the compressor on as I move from tire to tire.
I remember seeing a picture of schaefer (?) using his this way, but I can't remember where I saw it.
I've thought about going as primitive as using my jumper cables (6g) as the power link from the battery to the compressor; not sure if that's a good idea or not, even for a quick hack job. It would give me an easy "on/off" switch though.
So what do you folks think I need to do this? Am I on the right track? Better way to do it?
Thanks!
Old Jul 8, 2004 | 09:29 AM
jimbo74's Avatar
at least amke something a little more permanent.. even if that means just getting some wire and using crimp connectors to eyelets to the battery..... thats just plain ghetto....
Old Jul 8, 2004 | 09:41 AM
Scottiac's Avatar
and here I though just plain ghetto would be mounting the compressor in the middle of my hood and pretending it was a blower intake!
I do need some kind of on/off capability and want to be able to remove the setup for the 99% of the time I'm not using it. A quick-ish disconnect of some sort.
I suppose I could run some 4g leads from the battery to the cargo compartment with an inline switch on the positive line, but I'd still want a disconnect. Any other thoughts?
EDIT: What else do I need to worry about on the air side of the equation? Since I'm not using an air tank yet, and thus don't have a pressure shut off in the system, will a flow through chuck take care of making sure the compressor doesn't have a coronary when it's not actually filling a tire?
Old Jul 8, 2004 | 10:01 AM
jimbo74's Avatar
just get one of those tanks at kragens, for a portable one, they are only like $20
Old Jul 8, 2004 | 10:07 AM
Scottiac's Avatar
You're just bound and determined to make me do this right, aren't you?
Thanks for the input!
Old Jul 8, 2004 | 10:11 AM
WATRD's Avatar
You could do an in between step like I did and mount the compressor into a tool box, then build a proper power cord with a quick disconnect on one end and aligator clips on the other. It keeps the compressor protected and is a little less ghetto than what you are describing, while still being portable and not truly hard mounted...
http://www.watrd.com/work/Compressor/
Old Jul 8, 2004 | 04:16 PM
Arnold's Avatar
Here's my "ghetto" set up,
HERE
Old Jul 8, 2004 | 05:05 PM
Scottiac's Avatar
link no workie, but I found the pic on your albums. Thanks! That's pretty much exactly what I have in mind. Ghetto and all!
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
coryc85
Dec 5, 2015 08:42 AM
JUICE222
Oct 13, 2015 08:50 AM
Badlander
Oct 10, 2015 08:05 PM
