Any write ups for changing the drive shaft universial joints?
Old Jul 1, 2004 | 10:44 AM
934rnr's Avatar
I am in the process of changing my U-joint on my rear drive shaft. It basically had started to vibrate and squeak at low speeds. So I dropped the drive shaft and found a chunk of the bearing sleeve missing as well as all the needle bearings on one side of the u-joint. It was basically clunking back and forth when I checked for play.
To get the bearing caps out I used a 21 MM socket on top and a hammer and I think a 29 MM socket on the bottom to bang out the bearing caps into.
I have the u-joint off and I got a replacement joint for $14.71. The only question I have is how do I reinstall the new joint?
I have a large C-Clamp that may work as a press I guess.
What do you think?
Old Jul 1, 2004 | 02:09 PM
934rnr's Avatar
I had to use my dremel with a combo of grinding the corners of the old u-joint it came right out. Before I threw everything out I noticed one side there were no needle bearings left in the cap...
Other good news I used a combo of using a big C-Clamp and a socket with my small sledge hammer I got the new joint in with no issues.
Old Jul 1, 2004 | 02:33 PM
TechWrench's Avatar
Just be sure to seat all four end caps against the retaining clips so there is no load against the center cross ends. Most U-joint failures after replacement come from not seating the end caps.
Old Jul 1, 2004 | 03:12 PM
934rnr's Avatar
I made sure I did that. This about my second time replacing u-joints in my life it all came back to me. Thanks for the tip though.
Old Jul 1, 2004 | 04:21 PM
Roadrunner's Avatar
Over on the tech dept of Pirate4x4, there's a write-up. Not sure if changing a u-joint is pretty general from Toyota, Jeep, etc:
http://www.pirate4x4.com/tech/ujoint_install/
Old Jul 1, 2004 | 05:46 PM
Yoda's Avatar
Make sure you gease the crap out of it! Most times, the grease in it when you buy it is to keep it from rusting in storage. During assembly, I fill each cup with synthetic grease. When done, I grease the zerk, after about a week, I grease the zerk again. Then I do it at normal intervals, or anytime i'm into any substantial water.
Old Jul 2, 2004 | 06:35 AM
934rnr's Avatar
They came pre greased with synthetic grease they also have little red boots on each joint to retain the grease.
I did check to see how much grease was in each cup they all had quite a bit of grease in them already so I didn't think I had to put any grease in therm.
The only issue is these do not have a zerk fittings on them like the stock one did. I asked the guy at the parts counter if they have a lifetime warrenty on the u-joint and they do. I may just drill a hole in it and tap in a zerk fitting for GP on it.
Old Jul 2, 2004 | 08:40 AM
934rnr's Avatar
Oh BTW while you have your driveshaft off torque check the transfer case output flange and the rear diff flange I got at least 1/2 turn before they started to tighten. They are a 30 MM nut if you don't have a 30 MM socket a 1 3/16" socket will work for it. Remember to steak off the nut when you are done. I did test drive it today it's so much better now. The driveshaft vibe is pretty much gone however it does come back a little at abut 80 Mph but I don't normally drive my runner that fast so it's no biggie.
Jdgarrison
Oct 1, 2015 05:22 PM
ItsJustD
Jul 7, 2015 07:49 AM
Jnkml
Jul 6, 2015 01:20 PM
wilbertd
Jul 6, 2015 07:39 AM
ptb12
Jul 5, 2015 01:49 PM
