Worn Panhard Bolt
Old Jun 25, 2004 | 03:45 PM
cubuff4runner's Avatar
Worn Panhard Bolt
I have been getting a cluncking noise from the rear. It seemed like it was coming from the lower panhard bolt. I removed the bolt shook my runner and the sound was gone. The bolt is slightly worn in the center. How tight should the bolt fit inside the metal grommet insert on the panhard? Also has anybody else ever had this problem?
Old Jun 25, 2004 | 04:02 PM
waskillywabbit's Avatar
Talking Pic
A picture would be worth a thousand words...
Old Jun 25, 2004 | 04:23 PM
You would think that I would learn to post pics by now :pat: Here are a couple. My digital camera is old so it doesn't take the best pics.
Old Jun 25, 2004 | 04:24 PM
Another
Old Jun 25, 2004 | 05:07 PM
Talking Tight Fit
When I put mine back together it was a real tight fit and I had to whack the bolt with a hammer a few times to get it through. I haven't had any clunking either. From those pics it doesn't look like any serious wear is occurring. Perhaps you could put it back in, tighten it down, see if it clunks again, and then look for a slightly bigger bushing. Do you have all the spacers in there like Schaefer suggests?
Old Jun 25, 2004 | 06:04 PM
I have taken it apart and retightened the bolt a couple of times and the same thing happens. It is tight in the bracket on the sides with the nut and bolt, it is when you rock the vehicle side to side that it makes the noise. I think tommorrow I am going to the hardware store to find a bolt that fits tighter.
Old Jun 25, 2004 | 06:34 PM
Talking Panhard
Did you fab your own panhard or buy one of schaefer's or something else?
Old Jun 25, 2004 | 07:09 PM
FattyCBR's Avatar
I have a similar problem with my driver's side lower control arm. I replaced the control arm and bolt and the clunk is gone for now. I would try just ordering a new bolt from Toyota.
Old Jun 25, 2004 | 08:03 PM
4RUNR's Avatar
Guest
I've had the clank after doing some work back there, turned out it wasn't tight enough. No wear on the bolt though. The advice I got here was IIRC 60lb/ft factory setting and it fixed it.
Old Jun 25, 2004 | 08:06 PM
4RUNR's Avatar
Guest
That does not look like a worn bolt though. That looks like the wrong size bolt! On the ’99, when I put a layer of grease on the bolt it fit snug.
Old Jun 26, 2004 | 07:29 AM
I picked up the same size bolt today and the old one was definately worn. Here is a pic to compare the difference.
No More Cluncking
Old Nov 1, 2012 | 02:09 PM
hrt4me's Avatar
thanks for the torque spec
Pocoyota
Sep 8, 2015 02:41 PM
fabing455
Sep 7, 2015 08:08 AM
eggens
Sep 5, 2015 12:16 AM
Aaron Logan
Sep 3, 2015 08:08 AM
