fabtech lift...do you like it?
So I'm looking into a 3.5" fabtech performance lift, and I'm wondering who out there has this, or has had it. If you got some experience with this setup, I'd love to hear about/
Thanks,
Ian
Thanks,
Ian
i have the 4" fabtech spindle... it doesnt improve any suspension geometry or anything like the one you are looking at... but fabtech is a GREAT company, very top notch.... other than the price, its awesome... go ofr it
Is your truck a 4WD? If so the Fabtech kit that includes upper a-arms will not work. Also if your truck is 4WD (even with manual hubs) the most lift you can properly run is 2.5". By lifting the truck (with stock width basic lift kits) you are not gaining any actual suspension travel you are just setting where the truck sits in the stroke of it's travel (higher or lower). The Tacoma has about 7" of travel stock, and it sits more or less 50/50 right in the middle of it's stroke which equals about 3.5" of bump (up-travel) and 3.5" of droop (down-travel). So by lifting the truck 3.5" you basically have zero droop and close to 7" of bump. Having the truck sit like that will make it ride terrible on anything other than the smoothest paved roads. If you want to keep the truck stock track width and gain a tremendous amount of performance, the only way to accomplish that is by adding a coil-over system that actually has more stroke than the stock shocks do. The only product that fits that description on the market today is the Donahoe Racing coil-over. It will allow for almost 9" of travel when combined with Total Chaos uni-ball upper control arms (which are designed to sit at close to stock angles on a slightly lifted truck). If you have a 2WD truck Fabtech's lift spindles are a great idea because they provide lift by pushing the wheels down farther away from the truck but they don't actually change the suspension geometry. This is why lift spindles work with 2WD and don't work with 4WD trucks.
Thanks,
Ian
Thanks,
Ian
Zero problems with it since then. The new version bushings are showing zero wear.
*snip*
*snip*
(btw, what about lifting the rear with aal's? I presume one just needs switch to a longer travel shock, yes?)
thanks,
Ian
Thanks,
Ian
Thanks,
Ian
Downey AAL in the rear and Bilstein 5100's (longer than stock) will ride very nice.
Do you have a 4wd? or Prerunner?
Originally Posted by calamaridog
I would recommend SAWS ($650), Kings ($850), or Donahoes ($950) over Fagtech products any day. Set them at 2-2.5 inches of lift for a nice ride. All are better coilovers than the Fagtechs. All offer more "performance" than the Fagtechs.
so I'm getting conflicting messages (big suprise) are aal's good or is it better to replace the whole leafpack as stated above?
I'm sure this is all hashed out here on a yearly basis, but what the heck.
Also, anyone know the sites for the above companies? (google here I come)
i have SAWs and revtek diff drop in the front (set at about 4" lift), AAL and shackles in the rear. (4.5" lift)
ride is fine, travel decent in the front, great in the rear. if you have the money, get the SAWs, and AALs are fine (and cheap) for your rear lift.
http://www.donahoeracing.com/ (Donahoes)
http://www.camburg.com/about.html (for SAWS)
http://www.kingshocks.com/ (I love my KINGS)
As far as the AAL goes, it is MUCH CHEAPER. This is why we are recommending it. Some AAL ride better than others. I like the Downey AAL.
New complete springs are very expensive $350-750. If you get the AAL and longer shocks now, you can defer the complete set until your stock springs are totally worn out or break. If money is no concern, then knock yourself out
Regarding the Downey's, I was checking out that site and it appears that what they sell are complete rear spring assemblies (at a very reasonable price), am I misreading the info (I wouldn't be suprised).
Thanks for the links, and for everyones input and insight.
[QUOTE=SEAN_at_TLT]
*edit*If you want to keep the truck stock track width and gain a tremendous amount of performance, the only way to accomplish that is by adding a coil-over system that actually has more stroke than the stock shocks do. The only product that fits that description on the market today is the Donahoe Racing coil-over. It will allow for almost 9" of travel when combined with Total Chaos uni-ball upper control arms (which are designed to sit at close to stock angles on a slightly lifted truck). *edit*QUOTE]
Must the upper and or lower Arms be replaced, or is it possible to gain a reasonable increase in both lift and travel (although obviously reduced) while replacing ONLY the coilver?
back up there
looking at some SAWS on ebay, so I thought I'd try and revive this.
Of the better coilover makers, is it correct that only donahoes (or maybe it was kings, it has been a good two minutes since re-reading this thread) allow for increased travel, instead of just reducing the available droop? I know loads of you have SAWS, love 'em? Hate 'em?
thanks,
Ian
thanks,
Ian
This response was posted at TTORA recently by one of the guys at Donahoe.
"Well there are a few reasons why the Donahoe shock is better. We have the most wheel travel of all the coil-overs on the market. It has the tightest packaging available at full compression. The oil we use is Torco 7wt Synthetic for the best possible life. Torco is the same oil we use in all our Trophy Truck Race truck shocks we have ever built.We use a chrome silicon spring of highest quality that can hold extra loads like bumpers and winches with out sagging. It’s the only shock with spring good enough to have a guaranteed not to sag warrantee. We use a nitro steel shaft that will not pit or rust (all chrome shafts will.). We make the only coil-over with a hydraulic droop stop at full extension. (This is a huge plus for never getting a clunk noise on droop and never feeling the jerk on the wheels). On top of all that we have the only digressive piston in a Tacoma coil-over. This allows us way more valving capabilities for more bleed with lots of rebound control that a linier piston (all other shocks) can not offer. With all the cool components it means nothing unless you test, test and test some more. Donahoe Racing is the only Shock manufacturer that is actually racing on the product. The same Coil-over that you buy from us has ran the Baja 1000 off the shelf. And the other huge factor is we have been designing racing suspension science the 70’s. That’s Longer the ALL our competitors."
Now with that being said, I love my Kings
and haven't had a chance to ride or drive in a Donahoe equipped truck. You can find used kings now for around $700 bucks in excellent shape, as a matter of fact, Jason Demello had several good used pairs recently.
