Question about trd thermostat?
I have a 98 4Runner V6 4wd.If I replace my stock thermostat with a trd low temp thermostat, what are the benefits/drawbacks? While I'm at it I want to ask how do I clean the MAF sensor? I've read up on it on a website (don't remember which one), but my MAF looks a little different than the one they showed. My MAF looks like it's one piece that is part of the tube after the stock box. Anybody have any ideas/suggestions or has the same setup.? Thanks.
Avoid the TRD piece and just buy a regular low temp (180F) thermostat for under $10. I ran a 10 degree lower temp themostat in my Eclipse for years and it was just a plain one from Pep Boys.
If your engine doesnt' overheat, stay with the stock one.
As you can see in my signature, I have TRD S/C with 7th injector kit, and although TRD recommends to use their thermostat, I stayed with the stock one. When I was using TRD thermostat, I would sometimes stall because of overheating. Going back to stock resolved all the problems.
-- Andrey
-- Andrey
Thanks for responding so quickly, the reason why I was asking was because yesterday my car overheated. The airconditonining was on and I was in stop and go traffic. When I turned the air off, the car went back to normal, even inb the stop and go traffic. I was wondering since I have to replace the thermostat, which I'm assuming should fix the problem, should I go with trd.
I have one as well, along with the higher pressure radiator cap.
TRD Sports thermostat 00602-17621-001
Thermostat, 3.4 V6
TRD Radiator Cap 00642-16401-002
S-Type, 21.3psi
Thats really all that is in English, the rest is Japanese
Thermostat, 3.4 V6
S-Type, 21.3psi
the1998sr5
15
Jul 14, 2020 08:35 PM
Toyvana
Jul 29, 2015 10:47 PM
0060217621001, 34, 4runner, boys, highlander, pep, replace, sports, tacoma, thermostat, theromstat, toyota, trd, tstat, urd
