Best oil for high mileage
All my mechanic friends have always told me to stay away from penzoil becase they said it "gunks up your engine". They allso say that the high milage stuff can oversofen your seals if you use it all the time. I just run 10w40 instead of 10w30 of a high priced sinthetic and call it good.
I have used castrol 10w 40 for 12 years and havent had a problem.
I recently switched to castrol high mileage. I only have a couple hundred miles with it, but it seems to be fine. I guess I'll find out in the long run.
Are you having some specific problem you are trying to correct? If not there is no need for that marketing hype oil.
The best oil you can use in any engine, any mileage is AMSOIL. It has the max amount of benificial additives. There is nothing out on the market that can touch it. They have been making sure of that since 1972.
www.GadgetOnline.com/AMSOIL.htm
Gadget
Gadget
Originally Posted by Midnight Rider
I've used Shell Rotella 15w30 in my truck since I bought it. It had 220,000 on the clock when I bought her...
Chuck
Chuck
Uhh.. I use this in my diesel lawn tractor. I didn't know it was for gas motors too.. I guess it works!
I wanted to quote both of Gadget's posts and agree, but since you can only do one I just typed this instead...
High mileage oils are a bunch of marketing hype, just like the 3000 mile oil change interval that has been perpetuated by the quick lube industry and their desire to increase their bottom line.
Synthetics aren't cost-effective unless you increase the drain intervals -- just expensive insurance. However, AMSOIL does in fact save you money at their recommended intervals. I ran the same oil in my Tundra for over 2 years without a drain. I tested it and changed the filters and the results kept coming back that it was good for continued use so I kept running it. And in the process I used different labs so I'm confident all was on the up and up.
Bottom line: use what you are comfortable with and change it at the recommended interval provided. You'll note that few oils offer a recommended drain interval, in hopes you will drain early and buy more...
~ Fred
~ Fred
Gadget
Gadget
Sep 4, 2015 09:27 AM
