need info on replacing stock clutch cooling fan w/ flex-a-lite
Old May 6, 2004 | 03:05 PM
RufusRunner's Avatar
I own a '95 4runner, and I'm planning on buying a flex-a-lite metal fan (not electric) but not only do I not know the diameter of the stock fan (the blades got in a fight w/ the shroud) and I dont know how big of a spacer I need. If anyone else has done this, any input would be awesome. Like I said its for a 95 4runner 3.0 3-VZE. Thanks in advance.
Old May 6, 2004 | 04:10 PM
Bueller...bueller?
Old May 7, 2004 | 06:05 PM
any takers? help would be nice...
Old May 7, 2004 | 06:21 PM
Yoter's Avatar
Guest
hang out for a min and i will run out to measure mine. brb
Old May 7, 2004 | 06:27 PM
Yoter's Avatar
Guest
Ok I measured 2.5 inches from the back of the radiator to the front of the factory fan blades. I measured 3.5 inches from the timing cover to the back of the factory fan blades & a measurment of 19 inches on the fans diameter. Hope this helps yuh. Ben
Old May 7, 2004 | 06:32 PM
thank you sir.
Old May 7, 2004 | 06:36 PM
Yoter's Avatar
Guest
Originally Posted by RufusRunner
thank you sir.
No problem at all.
Old May 7, 2004 | 06:42 PM
Yoter's Avatar
Guest
In trade for my help will you do me a favor? When you get your parts can you give me a small write up of what you did to swap it and a few part numbers? I might just do this aswell. Ben
Old May 7, 2004 | 09:05 PM
yeah, If I'm successful, I'll do a write up, but thats a big if. I found a 17" flexalite fan w/ a 1.5" spacer on e-bay for like $20, and from what I understand, a bolt-on kit is the main thing I need to worry about.
Old May 8, 2004 | 11:50 AM
yeah, that looks about right, now would that fan and spacer bolt on, or would I need a seperate kit for that?
seafarinman
May 12, 2014 08:12 PM
TexJJ
May 30, 2006 08:37 AM
4Runner1988
13
Sep 9, 2004 01:44 PM
boss hog
9
Aug 18, 2003 02:20 PM
landman
Aug 18, 2003 08:51 AM
