22re starts then stops immediately despite effort
Old Jun 4, 2026 | 04:33 PM
sethw250's Avatar
Hello everyone, I just got a 86 Toyota pickup with a 22re, it had sat for about 8 years before I fixed the gas tank then it fired up for about 3 minutes, after that I’d go to start it then it would run for about 1-4 seconds then shut off. I jumped the Fp and b+ diagnostic port to get it continuously running, along with a new fuel filter. Same problem. Pulled the intake manifold and fuel rail to clean the injectors. Pretty sure I did a good job. I have power to all my injectors as well. AFM opens as it should, not to sure where to go from here and it does run on starting fluid. Thanks guys!
Old Jun 4, 2026 | 05:24 PM
JoeS's Avatar
Did you install a new pump.My EOM one went out at ~325K.
Old Jun 6, 2026 | 08:58 PM
the_supernerd's Avatar
My first thought is something to do with poor fuel flow, so when the pump runs it builds pressure, but then loses it quickly when the injectors open. Possibly a faulty pump, clogged pickup screen, or a severely restricted fuel line. The other possibility is maybe the AFM is not sending a proper signal to to ECU even though it is running the fuel pump.
Mazamaryan1
Mar 25, 2024 04:48 PM
dnroe
Jan 6, 2023 10:59 AM
Melvinfromnowhere
Jul 20, 2022 04:18 PM
Doug4320
Apr 13, 2015 12:04 PM
Sonofmayhem
Jun 9, 2007 10:33 PM
