Should new pilot bearing slide on input shaft?
I am putting a new engine in my '95, I ordered a new Asin clutch kit, it has a brand new Koyo bearing in the kit, the issue is that when I attempt to slide the bearing on the input shaft it only goes on about a quarter inch, I am thinking this should slide all the way on the input shaft, correct?
[img alt="This is as far as it will go.....
"]https://cimg4.ibsrv.net/gimg/www.yotatech.com-vbulletin/2000x926/20241118_220236_25b380234439ac118f9870f7c69a4b04ac fad6f3.jpg[/img]
From: exo-reality -wave if you see me; Front Range, CO
You've not got an answer yet, so I'll be first to show my ignance.
The pilot bearing = that goes into the flywheel - supports the very small necked down part of trans input shaft. So yes, your bearing must fit over the smaill pointy part of input shaft.
Unless I'm totally missing what you're asking.
If you aren't sure about your inpt shaft, try running your fingernail, if you have any, down each groove on the input shaft, and feel for burrs/anything sticking up. Same with the bearing. Don't use a dental tool. Not sensitive enough. If you can't use your finger nail get your wife or girlfriend, or both, to help
Generally, they get a kick out of helping mechanic husbands/boyfriends do something mechanical, especially on a vehicle they use, even on occaision.
Pat☺
Generally, they get a kick out of helping mechanic husbands/boyfriends do something mechanical, especially on a vehicle they use, even on occaision.Pat☺
rwas
Aug 25, 2024 02:37 PM
wilshire
Apr 30, 2010 06:00 PM
