Anyone replaced tailgate window *inner* weatherstrip?
Old May 24, 2024 | 07:10 PM
Blueman's Avatar
I have a replacement outer weatherstrip (68160-89111, AKA 68160A) which comes (nicely) with all the clips. Trouble is, I'd also like to replace the inner weatherstrip, which is very similar, but slightly different (has an extra lower felt seal and curl to it). Have others just used the outer seal in the inner position since it's more available? I have a part on order (68170-89114) for the inner, but am skeptical it'll arrive since it's a discontinued part.
The trick for removing the outer weatherstripping without removing the glass is to use a thin putty knife, BTW. Come from each side, and release the two side hooks of each of the eight retention clips, and then pivot the weather strip forward/backward to get the center tang to release.
1987 4Runner, Gen1
Old May 25, 2024 | 10:21 AM
osv's Avatar
osv
thx for the tip on removal... i wonder if the inner rubber on the doors would work, even if it required two pieces.
Old May 25, 2024 | 01:22 PM
Jimkola's Avatar
YT Community Team
5 Year Member
I used an outer tailgate w/s to replace my inner
Spence1016
Jul 22, 2011 10:16 AM
dnbaugh
Jan 11, 2010 04:17 PM
Harold Of The Rocks
Oct 28, 2009 05:08 PM
Ontario
Apr 10, 2005 07:05 PM
beertestr
Feb 9, 2005 04:37 PM
