94 pickup 22re manual compressor clutch stays engaged
Ok I’ve searched for weeks online and haven’t found an answer.
if my blower is on, the clutch on the compressor engages. Doesn’t matter if I’m blowing heat on the floor the clutch is engaged. During AC it never cycles off. The system itself works, AC gets cold, heat gets hot. Help!!!!
replaced air drier, expansion valve, pressure switch, compressor is new. Tested blower relay. Cleaned evaporator, going to clean condenser. Messed with the dial on the amplifier with no change
not sure if it’s related but I do have idle issues. AC idle vsv works. Assuming it’s the diaphragm, have read posts about that and it’s in the works of correcting that
