94 pickup 22re manual compressor clutch stays engaged
Old Mar 26, 2024 | 03:16 AM
Cfleur's Avatar
Ok I’ve searched for weeks online and haven’t found an answer.
if my blower is on, the clutch on the compressor engages. Doesn’t matter if I’m blowing heat on the floor the clutch is engaged. During AC it never cycles off. The system itself works, AC gets cold, heat gets hot. Help!!!!
replaced air drier, expansion valve, pressure switch, compressor is new. Tested blower relay. Cleaned evaporator, going to clean condenser. Messed with the dial on the amplifier with no change
not sure if it’s related but I do have idle issues. AC idle vsv works. Assuming it’s the diaphragm, have read posts about that and it’s in the works of correcting that
86T4R_project
Apr 25, 2021 06:58 AM
Evan Reid
Jun 28, 2018 03:30 PM
808-3VZE
Sep 23, 2017 07:45 PM
jonwalden68
Jul 30, 2012 10:08 AM
Bobs4Runner
Jul 20, 2010 12:16 PM
