Bond Cable = Ground?
Old Mar 7, 2024 | 01:55 PM
prcnctoyo's Avatar
Found a broken wire today. One end bolts to firewall. The other end to the head near #4 plug. Toyota's description is the No. 1 Bond Cable. Is this a ground wire? With the amount of sludge on it I've been driving with it broken for awhile.
Old Mar 7, 2024 | 07:13 PM
millball's Avatar
It is a ground cable
Old Mar 8, 2024 | 02:03 PM
prcnctoyo's Avatar
I made a new one with what wire I had on hand. It's not the same gage as original. How important is the wire gage? Just want to know what priority I need to give this.
Old Mar 8, 2024 | 03:56 PM
millball's Avatar
Should be fine so long as not spiderweb thin.
Anything bigger than 16 gauge should be fine.
Doesn't even have to be insulated.
Old Mar 9, 2024 | 08:23 AM
mechkw's Avatar
Put another one somewhere else. I double ground everything now with the new electronics. You can go frame to cab down by the starter or even by the back of the cab
Old Mar 9, 2024 | 01:54 PM
2ToyGuy's Avatar
That ground grounds the head. That's where the spark plugs get their ground. The head(s) don't get a good ground through the block. They get one, yes, but it's not the best. That's why they have what's known as a bonding strap over to the sheet metal of the cab. That way it has a direct ground path to the battery. Presuming a ground from the sheet metal of the body to the battery negative is in place, and in good shape, as it should be.
That's why there's a bonding strap from the alternator up to the mounting for the power steering pump. That way the alternator has a good, direct path through the head to the battery negative.
I would make the new bonding strap at least the same gauge as the old one, or slightly larger. The Toyota engineers made the bonding strap the size it is for a reason. They've been known to do some stupid things, I grant you, but they weren't entirely useless. I'd wager the bonding straps were assigned to a junior member of their team, who did his very best to try and impress.
After all, they DID come up with the COR system. You gotta give them that....
Pat☺
Old Mar 9, 2024 | 03:03 PM
prcnctoyo's Avatar
Thanks All! I definitely plan to remake the ground with at least the same gauge wire. I just didn't want to drive it without one so went with what I had on hand. The truck is my DD. I don't remember seeing any wire that size at a local auto parts. The part # for the ground strap is discontinued otherwise if reasonably priced, I'd have ordered one.
I'm wondering if it had been broken free for awhile or when I pulled the valve cover I knocked it loose....
Old Mar 9, 2024 | 04:02 PM
akwheeler's Avatar
Most parts stores have generic ground straps in different lengths, search amazon for ground strap and you get a lot of options.
Just measure how long it needs to be. If it were electronics I would suggest going for quality, but for just braided metal or copper wire you should be fine.
You could also use a negative battery cable (black).
10ofclubs
Oct 21, 2021 11:46 AM
pendrag
7
Sep 5, 2012 12:06 AM
skitrev
Apr 18, 2006 09:17 PM
vhilts
Apr 4, 2005 09:27 PM
